Notices
Reply
Thread Tools Display Modes
  #21
Old 28-11-16, 18:02
heavy's Avatar
heavy heavy is offline
Van Expert
Default Re: New LT project!
ok thank you regards rikki
Sponsored Links
Advertisement
  #22
Old 29-11-16, 18:23
Alexhoc Alexhoc is online now
Van Guru
Official MemberVW Transporter
Quick update for today, windows are in and looking good, I have mostly finished flashbanding the van and I have insulated most of one side.
And here's a picture of the seats I forgot to take yesterday:
  #23
Old 01-12-16, 16:10
Van Guru
Insulation is in on the sides, I went with 2 layers of "loft" insulation, covered with a layer of the foil bubble wrap. For the floor, I hesitated a while and decided on raising the floor, and going with the same method:
Then I laid the plywood floor again. I went with 9mm ply to save weight, but I think I should have used more batons or thicker ply, as the floor is a bit "springy", shall we say. I decided to extend the floor between the seats too so I have a nice transition between the cab and the living area.
  #24
Old 02-12-16, 08:00
upspex's Avatar
upspex upspex is offline
Electrifying!!!
Official TraderVW Transporter
Nice work Alex, you could always beef up the floor by laying another layer of 9 mm sheet in opposing directions.
Electrics for camper vans and work vehicles.
www.travelvolts.net
INFO Text call back to 07971 165747 or travelvolts@gmail.com
Monday to Friday, 8 am to 5pm only. Yes, we have a life beyond working
NO PRIVATE MESSAGES PLEASE!
  #25
Old 02-12-16, 08:18
Van Guru
Thanks Martyn, I'm tempted to see how it fares once the build is "complete", I might try a dry fit of all the furniture first so it wouldn't be too much work taking it out again.
  #26
Old 02-12-16, 09:04
upspex's Avatar
Electrifying!!!
Good idea, there isn't actually that much floor space that gets walked on anyway!
www.travelvolts.net
  #27
Old 02-12-16, 15:59
Van Guru
I've spent some time getting my central locking kit wired up today, unfortunately it turns out every single wire is too short... Because of that I've not spent too much time getting the door cards off, but it doesn't look like they will want to come off... is there a trick to them?
The rest of the day was spent sprucing up the cab, I have covered the cab floor in a layer of sound deadening stuff and carpeted over, then protected the carpet with a new cab mat:
Tomorrow I'll make a start on the overhead cupboard in the cab. Not sure what to use to make the dashboard look better though...
  #28
Old 03-12-16, 08:39
upspex's Avatar
Electrifying!!!
If you look under the cover of the handle you will see a hole where you put a screwdriver to prise off the cover. This reveals the screws. Remove the lower paper map lockers and lift the door panel to release it. Carefully remove door release cable from rear of handle.
www.travelvolts.net
  #29
Old 03-12-16, 08:41
upspex's Avatar
Electrifying!!!
Top picture shows where to mount CDL motor.
Worth sound deadening in here too.
www.travelvolts.net
  #30
Old 03-12-16, 09:20
Van Guru
Oh lift the door panel? That explains why it won't unclip then!
Thanks for the pictures, they help a lot!
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
