Notices
Reply
Thread Tools Display Modes
  #31
Old 04-12-16, 18:01
Alexhoc Alexhoc is offline
Van Guru
Official MemberVW Transporter
Default Re: New LT project!
Not a very productive weekend, 2 Christmas dos made sure I didn't really feel like doing much work!
I've fitted the roof light and solar panel though! I made a wooden frame for the roof light, so it is Sikaflexed to the roof and screwed through the roof skin into the frame, which will also support the roof panels.
The solar panel is Sikaflexed in place and bolted through the roof skin too, for good measure. It's not connected to anything yet but as I was messing with the roof I thought it best to do all at once.
Sponsored Links
Advertisement
  #32
Old 04-12-16, 18:02
Van Guru
  #33
Old 08-12-16, 14:40
TheBeast's Avatar
TheBeast TheBeast is offline
Van Expert
Good to see progress already.
Keep it going. At this pace you'll be ready by the end of the Spring !
  #34
Old 08-12-16, 15:54
Van Guru
Thanks, I plan to be ready before that because I know what I'm like, if I start using the van while it's not finished, all the little jobs that need to be done will never get done. I want to go to France this winter, so the van has to be completed over the next 6 weeks. There's nothing like a deadline to keep you going!
At least I have a bit of a budget put to one side for it, so that doesn't delay me...
Any clever ideas on what to do with door cards and dashboard? Everything is going to be quite nice inside, except the front end plastics which look rather industrial!
  #35
Old 08-12-16, 16:34
Davemac429 Davemac429 is offline
Van Master Jedi
T5 Post Icon Re: New LT project!
Looking good mate keep up the good work
  #36
Old 09-12-16, 17:24
heavy's Avatar
heavy heavy is offline
Van Expert
ive decided to leave it until spring time and will remove dash and cards and all plastics, then cover all with dark and light grey leathercloth, and fir all other bits ie central locking , leccy windows , security locks, and audio all in one go
  #37
Old 09-12-16, 18:00
Van Guru
Quote:
Leather sounds pretty good, what's your plan to "make it fit"? I've seen a few that needed stitching, sounds like something that would be easy to get wrong...
  #38
Old 09-12-16, 19:43
heavy's Avatar
Van Expert
if you look at the panels there are no real compound curves, so a good adhesive and heat the cloth with a heat gun so its very soft you can smooth it on , it also depends how you separate the colours , or you could mix 4 way stretch carpet on some parts and cloth on the others,
  #39
Old 09-12-16, 19:57
heavy's Avatar
Van Expert
  #40
Old 10-12-16, 19:57
Van Guru
I finished the insulation today, it'll be cosy in there!
Tomorrow, I'll start boarding out and working out how everything is going to fit. I have had a thought about the cupboard over the cab, and the little cubby hole I want to build too, so hopefully they'll be there by tomorrow.
I made some progress with the central locking, however I can't get it to work, the mechanism in my door is different to the one you pictured Martyn. It's much shorter and I can't get the actuator to sit at the correct angle to push the lever properly...
I have to say I'm not a fan of these short days either!
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
