Notices
Reply
Thread Tools Display Modes
  #31
Old 24-09-15, 14:08
leeboy's Avatar
leeboy leeboy is offline
Van Pro
Official MemberVW Transporter
Default Re: Crafter high oil consumption
Quick update, 625 miles since lambda replaced and hasn't used a drop of oil 👍
Sponsored Links
Advertisement
  #32
Old 28-09-15, 13:24
crafter101 crafter101 is offline
Van Rookie
Thats good news.
I have had lambda replaced and the smoking has stopped.
Will keep an eye on it and post my results back soon.....
  #33
Old 12-09-16, 18:34
Dan Dan is offline
Van Man
Quote:
Originally Posted by leeboy View Post
My 109 was (maybe still is) using the same high quantities of oil, approx 2 litres every 500 miles or so. For various reasons I decided to have a DPF delete and re-map. Only Since then I noticed I was getting the clouds of white/grey smoke when you first touch the accelerator after a period of over-run. No smoke any other time. I asked the garage why it was not doing this before the re-map thinking it may be an over fuelling issue. They explained that problem was probably always there but because the EGR has now been switched off, all the smoke is coming out of the exhaust rather than being recirculated back around the engine. Makes some sense I guess.
But from various googling and the posts on here I decided to change the Lambda. Smoking stopped instantly! Relief...I'm keeping my fingers crossed that this will now cure the heavy oil consumption too. I only fitted it this week and haven't used it enough so far to see if it has, but will keep you posted.
Main dealer price for new lambda was somewhere in the region of 160. I bought a Bosch part from http://www.lambdapower.co.uk/default.asp for 103 and it arrived next day
Hi Lee, i saw your post about the crafter burning oil. Mine does the same thing, smells quite bad in slow traffic and gives a big puff of blue smoke when you get back on the throttle after coasting in gear.
The oil light comes on every 2 weeks or so depending on if i've been down devon or cornwall surfing.
Did the Lambda sensor cure your problem in the end?
Thanks, dan
  #34
Old 13-09-16, 20:43
leeboy's Avatar
Van Pro
Hi Dan,
Yes a lambda fixed mine with instant results. It's been a year since I replaced it, no more smoking and it uses just a drop of oil between services now
  #35
Old 08-11-16, 20:19
nzmikey nzmikey is offline
Van Rookie
Hi Dan,
What oil are you running in your VW thanks
  #36
Old 12-11-16, 00:36
Van Rookie
Hi Dan,
Hey man
What oil are you running in ya VW?
Im struggling with the oil consumption
Have pulled out dpf cleaned it out and put in new 02 / lambda sensor so hoping for improvement
Im running Penrite Enviro 5w-30
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
