Notices
Reply
Thread Tools Display Modes
  #21
Old 22-11-10, 18:59
twozup's Avatar
twozup twozup is offline
Lord of the T4s
I Support Cancer Research UK
Default Re: Carbon Monoxide
Tesco doing a good range of cheap CO2 detectors that take batteries- lasts for 5 YEARS!!!
Please bear in mind there are usually 2 types of gas detector- one that does CO2 and one that detects gas such as methane/ ether etc. (although the more expensive ones do both im sure).
Spend 10 now- live to see the sun getting up the next morning.
Sponsored Links
Advertisement
  #22
Old 25-01-11, 20:49
CruizingComet's Avatar
CruizingComet CruizingComet is offline
Van Guru
Help For Heroes
if you are going to get an alarm then get a decent "all in one" that detects Carbon monoxide as well as LPG & Narcotic gas
Looking around for one for our van these are the best I've found, not that pricey either (Under 60) : http://www.sola-larm.com/sla863.html
As for smoke alarms try to fit an Optical detector (Better suited to motorhome use) rather than the cheaper Ionisation type detectors.
  #23
Old 12-03-11, 20:21
cabstar cabstar is offline
Van Man
After buying a smoke / co detector please please please do not put a cheapskate battery in it!!! The times I used to sell smoke detectors & then the buyer would buy a 50p battery NO!!!!!!!!!!!!!!
Buy a duracell or an energizer, surely your life is worth more than 50p!!!!
  #24
Old 24-04-11, 00:52
jago25_98's Avatar
jago25_98 jago25_98 is offline
Van Jedi
Location: Bournemouth. 2.5tdi 102bhp 115k 1997, lwb hitop camper
What's really needed is all the gas bits to on the outside with doors that blow outwards in a fire, so all of it isn't even in the sleeping compartment. But where would that be fitted? Also, bear in mind that safety pressure release valves are generally designed to work with the canister vertical.
Had a fire training course last week and blew some canisters up. One of those small camping cans is enough to blow the doors off and kill everyone inside if it gets too hot.
-j
  #25
Old 29-08-11, 14:28
muddyhell muddyhell is offline
Serial Poster
Well a good friend of ours and past forum member has had recently had a serious scare through Carbon Monoxide....using a dying Cobb and CobbStone to heat an awning after cooking tea...it ended up in a 999 call and hospital..all safe and well now Thank God...
I'd reckon theres lots of us Cobb owners who have used them to heat the awning in this way...I now won't be..very Scary Stuff..
  #26
Old 23-11-11, 20:55
alan.surry's Avatar
alan.surry alan.surry is offline
Serial Poster
I Support CLIC Sargent
These are 50 plus in caravan shops. http://www.ebay.co.uk/itm/Discover-D...83809979261157
Mine detected a gas leak from my Smev cooker in a matter of minutes. It's permanently connected to the leisure batteries inside my cupboards & I'm considering another one to put outside the cupboards even though we always turn the valve off on the bottle after use. 16 is an absolute bargain.
  #27
Old 05-01-12, 18:13
Merry Monk's Avatar
Merry Monk Merry Monk is offline
Van Master Jedi
Ebay Item number: 370547062160
  #28
Old 18-02-12, 12:39
tonyr1664's Avatar
tonyr1664 tonyr1664 is offline
Lord of the T4s
I Support CLIC SargentHelp For Heroes
I bought this, smoke and CO
http://www.amazon.co.uk/Kidde-0122UK...9572320&sr=8-4
  #29
Old 19-02-12, 15:31
Harbourmaster Harbourmaster is offline
Van Guru
To those who are a bit confused, like me: CO2 is not Carbon Monoxide, it's Carbon Dioxide. CO is Carbon Monoxide.
CO/Carbon Monoxide is deadly; it's colourless, odourless, and tasteless. It forms when there is not enough oxygen to produce CO2/Carbon Dioxide; that's why people commit suicide by running a car engine in a garage. You won't even know it's happening. The Nazis used CO as one of their extermination gases, ironically in vans. Those s knew a thing or two about deadly gases.
SO, STAY SAFE PEOPLE!!!
  #30
Old 28-02-12, 09:56
forzali forzali is offline
Van Rookie
Good point Harbour, for those of us who weren't that attentive in Chemistry classes this entire discussion was a bit confusing
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
