I've had my 08 plate crafter (163bhp) 2.5 with 80k miles for 6 months or so and done around 4k miles, in that time its gone through over 10 litres of oil. Due to a slight leak on the oil cooler its been replaced, the oil use seems to be getting worse, there are no leaks around the engine, no blue smoke, it runs fine and does decent mpg. I've had the pipe from the turbo to the intercooler off yesterday and that was dry so turbo seems OK, it isn't a using water but there is a small amount of Mayo on the oil cap. I've noticed an oily smell on a couple of occasions when getting out of the van after a run. Any suggestions before it goes in to get taken to bits and costs a fortune?
Hi Guys I've read here on an older post about high oil consumption on a Volkswagen crafter 2.5tdi being resolved by replacing the lambda sensor but it doesn't specify which one. Anyone know the answer to this as I have no external oil leakage no smoke from exhaust crankcase breather valve is...
Hi there
Any updates I’ve developed same problem smoke on over run and oil consumption and don’t smell right
II think it’s had a dpf delete done
Jez
Related Threads
VW T4 Forum - VW T5 Forum
3.5M posts
221.6K members
Since 2007
