I have a sunroof on mine-just some pointers...
each corner drains to closest wheel arch- on the rear arches there is a rubber grommet just behind the interior panels located at the top of the arch- it doesnt go all the way through- drains onto the plastic cover inside the wheel arch- also has a flap to stop air blowing back up pipe to prevent buildup of water maybe?
not sure where front drains to sorry.
an aftermarket sunroof would be easier as the geniune one has a lip all the way around where the metal roof skin has been bent down- impossible to do yourself.
hope it helps...
Im having surrey sunroofs look at mine next week ,says T5s are tricky .dont think you can fit a sunroof in the rear as the roofs too ribbed but will ask !
My parents put a huge skylight in their transit conversion which has a ribbed roof.
They packed each groove up to the level of the top flat bits with flash banding type stuff, then one layer all round, then bonded with sikaflex (not sure which one)
It leaked, so don't do it that way!
It didn't help that the guy they got to cut the hole for it didn't put round corners in. Idiot.
Djvan...Are you putting a sunroof in the rear to hide the holes?
The holes in the roof towards the front for the ex aa arials are going to be tv arials colour coded i think. I will just unscrew the little bits for traveling so it doesnt look to wierd.
The small flat round one at the front will just be blanked as i have no idea what to use that for T:
The short flat one is a gps aerial for their tracking system ,they are stuck and bolted but you may damage the paint trying !
No i had a £500 Webasto slide and tilt with autoclose fitted to my T4 and its fanatastic bit of kit ,i hate air con and want some fresh air ,great for driving home at 3am with sounds pumping !!
Related Threads
VW T4 Forum - VW T5 Forum
3.5M posts
221.6K members
Since 2007
