Reply
Thread Tools Display Modes
  #231
Old 30-11-08, 23:06
Simon Baxter Simon Baxter is offline
Default Re: 1.9 PP thread
Note to those wanting to put a turbo on a NA engine.
Yes, it will work.
Compression ratio won't really matter that much, what will is that the pistons between the 1X and the ABL are different.
The ABL ones are treated with some special "stuff" that makes them more resilient to the extra heat/pressure.
As far as I know the 1X also have the oil cooling jets that spray oil onto the back of the bores to keep them cool.
I checked recently for something else and as far as I can remember they are dimensionally the same but it's what they are treated with after manufacture that makes them have different part numbers.
I'm fairly sure the 1X pistons are the same as the AAB ones from the 2.4D 5 pot motor.
Sponsored Links
Advertisement
  #232
Old 01-12-08, 11:46
paul ss's Avatar
paul ss paul ss is offline
Serial Poster
there aint much point ruuning it from a water bottle like screen wash as basicly only real time it is benifcial is in summer but the water is going to be warm .
there is charge coolers and dry ice which you cant run dry ice .
proper thing is the way forward i persnoly dont like them but go for it and lets see the results.
as for lowering the inlet temps you can lag the pipes but all these are bit wasted i persnoaly think on a van that is never going to be fast .
  #233
Old 01-12-08, 11:50
paul ss's Avatar
Serial Poster
Quote:
Yes, it will work.
1.9 and 1.9td x1 engines both have oil squirters in the bottom of the block either way they are not that inportant neither is compreshion ration for the sort of boost a t4 runs if im honest .
the pistons are ceramic coated but x1 pistons are forged from the factory so am told and looking at them it looks like it is true .
slightly higher compreshion of a non turbo will make you bit more extra power than standard due to very small diffrence in compreshion ratio , suppose this could be altered by head but realy is no bother.
Sponsored Links
Advertisement
  #234
Old 01-12-08, 17:23
DavieT4's Avatar
DavieT4 DavieT4 is offline
Serial Poster
I Support Children In Need
They don't have to be expensive.
http://shop.airworlduk.com/exhaust-g...auges-29-c.asp
Ring the guy, he's a nice chap by all accounts and is quite used to VW pervs ringing up for pyrometers!
What should you be running? about 1000F top side, short bursts above okay, but not for long!
nice one Simon
  #235
Old 03-12-08, 21:49
N13L VV's Avatar
N13L VV N13L VV is offline
Van Guru
Right due to my van not starting this past few cold frosty mornings, i decided to change the glowplugs . Anyway once they were done and i had the radiator pulled foward I remembered this thread and decided to PP mine . First off I got the anti tamper thing off the pump and turned it in and out until i was happy with the idle . Its higher but i can live with it . I had already blanked the EGR so i took off the wee clip on the actuator arm and wound it in shorter. Then went for a spin . WOW holy what a difference . It spun when i pulled second , how chuffed i am . Normally from my drive to my uncles gates i can get 65ish tried it today after the pp upgrade and 75 no probs .
Going to do the decat now in the next couple of days . Will decat make a noticable differance now?
Cant believe how much better this makes it to drive . seriously anybody if your not sure whether its worth doing believe me it IS.
  #236
Old 03-12-08, 22:26
Did you read what I posted?
Yep, great gains in the short term but you really need to do some other work before you kill it.
  #237
Old 03-12-08, 22:55
N13L VV's Avatar
Van Guru
I have just re read the whole thread but what other work do you recomend? Has most of the guys on here not just done the same as me , pump , actuator arm and EGR blank? In the next couple of days im going to bin the cat but i wasnt goingto go to the hassle of an intercooler . Do I need to?
  #238
Old 04-12-08, 07:51
steiner steiner is offline
Van Master Jedi
yeh do the cooler! and get a boost gauge!!!
I boost to 18 psi but have done all mods and got big cooler and different turbo
  #239
Old 04-12-08, 09:47
N13L VV's Avatar
Van Guru
i have a boost guage and it only boosting to about 0.75 bar but i notice a good difference over standard.
  #240
Old 04-12-08, 12:06
Van Master Jedi
with the pp mods you should be looking at safe boost of 12-13 psi maybe even 14-15 which is 1 bar so your boosting safe at mo, put an intercooler on and de-cat another huge difference
Reply
Tags
1.9td tuning
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
that 'best thread' thread got me thinking... leviticus18_23 General T4 Chat 4 08-12-11 14:48
EGR thread - where's it gone? Gasman Engine & Gearbox 43 10-03-09 17:06
The VW MAN Thread StephenTazz T4 Articles & Information 10 01-02-09 17:20
Another how much thread Transpunter General Technical 5 04-02-08 17:20
