Reply
Thread Tools Display Modes
  #101
Old 22-01-11, 21:08
andyd's Avatar
andyd andyd is offline
Lord of the T4s
Default Re: Andy's 1.9 TDI Conversion AHU
Quote:
Originally Posted by JIMMYJAMES View Post
It drives off the intermidiate shaft and the same shaft also drives the oil pump. Its quite a long rod
is this something i couldve d up? dont think i touched it.
i only changed oil pickup inside and sump, and removed lid and seal from vacuum pump, cleaned and replaced.
Sponsored Links
Advertisement
  #102
Old 22-01-11, 21:12
JIMMYJAMES's Avatar
JIMMYJAMES JIMMYJAMES is offline
Somebody stop me!
Regional CoordinatorOfficial MemberVW Transporter
Location: Whissonsett, in sunny Norfolk. (yes there is a place with such a name)
Doubtful bud especially if it was ok in the donor car. Any play or weeping from the oil pump pulley??
  #103
Old 22-01-11, 21:45
andyd's Avatar
Lord of the T4s
oil pump pulley? youve lost me. im up to my tdiballs and confusing me isnt difficult
all i did with the pickup was unbolt it and bolted it into the ahu engine, it worked in the abl so didnt check anything
if you mean the lower pulley that drives the power steering pump and aux belt i used the abl one and all seems dry down that end of the engine
Sponsored Links
Advertisement
  #104
Old 23-01-11, 10:20
andyd's Avatar
Lord of the T4s
ive been thinking, is there anyway ive fitted the pickup incorrectly? dont want to take sump off really unless i have really stuffed up, dug through my phone and found a pick after id swapped the pickup, i undid the two really long 13mm bolts and swapped the entire unit rather than just the end of the pickup,
without a in at all would the vacuum pump still spin? just want to be sure, cant find a schematic showing what drives what inside the engine
i've compared it to the picture in aggies thread and the orientation looks correct, i cant remember what the mating end looked like, if my memory is correct it was a slot on the end of the shaft and i had to rotate a tad to get it to mate before it would fit flush against the underside of the block.
dont think im going to get near the van today as ive already pushed my luck to breaking point with pass outs to work on this van!! going to have to spend sunday away from investigating to keep the boss happy!
according to the green transporter manual (not the best but better than nothing) it says, "the drive for the oil pump is taken from the exhauster pump (vacuum pump) which is fitted for the operation of the brake servo unit."
hmmmmm
  #105
Old 23-01-11, 13:50
1958steveflying 1958steveflying is offline
Van Master Jedi
The vac pump has a gear and is driven direct from the intermediate shaft, the oil pump has a male shaft with flats on it and is driven from the bottom of the vac pump.
  #106
Old 23-01-11, 14:17
andyd's Avatar
Lord of the T4s
so theres no way it could be fitted incorrectly causing the pump not to function?
can i start engine with lid of vac pump off to see if its rotating?
or shall i just fit van one?
  #107
Old 23-01-11, 17:06
mace's Avatar
mace mace is offline
Van Master Jedi
  #108
Old 23-01-11, 20:27
andyd's Avatar
Lord of the T4s
right managed to squeeze an hour or so in this evening, dragged the abl garden ornament into the garage and got it up on the stand and had a gander inside, i can see how it works now cheers mace for the image though, ive put my mind at rest that all is ok in there.
also had a look inside the abl vac pump
so I'm happy that my pump is spinning, so set about removing the lid to check i had definitely replaced the seal , which upon removal all looked fine.
What i did however notice is that i had connected the small pipe that comes down from beside the heater matrix water hoses (by bleed valve) to the smaller side of the one way valve and blanked the larger side.
So rang my mate with a abl and got him to check, turns out that this pipe (whatever it is) should go to the larger side of the valve! The smaller side was blanked on both ours as this side used to feed to the egr which we both removed.
Question is would this incorrect connection cause a lock in the valve? Seems believable.
heres how it shouldve been blanked (ready to go back on)
Didnt try it as need to leave it stripped down to change the cooler bracket gasket that i should hopefully be getting tomorrow. Maybe be able to add to my 400m of TDI experiences tomorrow and be added to the club tdi !!
Question, Can i get away with changing this gasket without removing oil filter and oil cooler from the bracket? Its only oilways on the block so should be ok if i can get a flexi joint on the top bracket bolt?? anyone done it?
  #109
Old 24-01-11, 16:08
andyd's Avatar
Lord of the T4s
anyone????
  #110
Old 24-01-11, 17:51
mace's Avatar
Van Master Jedi
You can change the gasket with everything still attached, just pull the filter/cooler housing back a bit and make sure both surfaces are clean and free from debris and slip the new gasket in place.
What do you mean by a flexi joint on the top bracket dude ?
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
