Reply
Thread Tools Display Modes
  #21
Old 05-02-12, 18:16
shellenpatrick's Avatar
shellenpatrick shellenpatrick is offline
Van Pro
Default Re: Flashing oil pressure warning problems
I'm asking because it is not obvious to me, if i'm being as thick as F*&%, i do apologise, but i asked the question in good faith, after reading the whole post.
I'm trying to make sense of the problem in my own head to help me fix it!
Sponsored Links
Advertisement
  #22
Old 05-02-12, 19:00
penbryn penbryn is offline
Lord of the T4s
I Support CLIC Sargent
This bit of post #1 should kinda give it away...
Quote:
...monitors the low pressure sensor when the engine is below 2000 rpm and the high pressure sensor above 2000 RPM. This is done via the instrument panel which uses the 'w' terminal on the alternator to measure engine RPM...
  #23
Old 07-02-12, 07:08
Damian Cane Damian Cane is offline
Van Rookie
Ok Can I ask and forgive me if this is stupid, but is this Petrol engines and diesels or just one?
I have no buzzer noises and no flashing lights whilst driving, but I do have an intermittent starting issue (see other post) that when It wont start, after cranking the oil light flashes
any advice please?
Sponsored Links
Advertisement
  #24
Old 07-02-12, 07:51
tthomas's Avatar
tthomas tthomas is offline
Van Master Jedi
I know this is probably irrelevant to the T4 but on some of the earlier 1.8T petrol engines there was an oil pressure issue which triggers the low pressure warning light & buzzer, but this is caused by the sump pick up being blocked. This happens on the early ones because the sump was too small which causes the oil in the sump to too hot which in turn burns the oil on the inside of the sump, these burnt bits then break loose & start blocking the sump pick up. It's a simple one to sort out but a difficult one to diagnose. It's a good reason to use good quality oil.
Rich
  #25
Old 07-02-12, 08:18
Lord of the T4s
Quote:
Nope - applies to petrol engines also
any advice please?
The light flashes because the engine is not running... i.e. no oil pressure = the oil pressure warning is working!
  #26
Old 07-02-12, 08:26
Lord of the T4s
Quote:
Rich
Forgive me, but it is difficult to see how this (although useful information to someone with 1.8T I'm sure) is of relevance to the DOP oil pressure warning system faults. 1.8T-engined vehicles didn't have DOP and nor was such an engine ever available in the T4...unless you converted but then one would also change the sump which you indicate is the root of the problem.
  #27
Old 08-02-12, 07:36
Van Rookie
Ok thanks, I guess that is a good thing then, however any one able to advise me about my starter issues (see other thread intermittent starting issues. Thanks
  #28
Old 29-02-12, 19:02
Van Pro
T4 Post Icon Re: Flashing oil pressure warning problems
Just goes to show, listen people befoire opver-complicating things with your own confused mind!
Front end on axle stands, sump guard off, quick check over everything and there it is......
...both wires going into alternator had been cut and badly re-acquainted!
Stripped them, soldered them heat wrapped them and went for a spin - not a peep.
Thank you Penbryn and plese forive my initial tardy attitude
  #29
Old 12-03-12, 14:42
yellowsubt4 yellowsubt4 is offline
Van Rookie
Hi Penbryn, I have the common oil light flashing at all rev's , I checked the wires off the back of the alternator and although they are waring through near the alternator there is no break and resistance is ok to dashboard. Do you know how to test the signal the alternator is giving off for reveal counter? I put a multimeter on the blue wire and got just over 14v with engine running, is this correct?
  #30
Old 03-05-12, 09:04
baffin baffin is offline
Van Rookie
Thumbs up Re: Flashing oil pressure warning problems
Cheers Penbryn
Really good summary and offers good clarity, I have got the same issue.
Would you have any advise on removing the dials on instrument panel so i can replace a broken Oil LED, just bought a 2.4 T4 and previous owner addressed this issue by cutting wires and busting the LED to stop flashing(reckon he tried to get led out with a hammer ). Its a good engine and bus and deserves some TLC.
Reply
Tags
oil light
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
