Reply
Thread Tools Display Modes
  #11
Old 04-02-12, 18:44
bigt bigt is offline
Van Master Jedi
Default Re: FroZen Brakes
-8 last evening. Mine frozen on as well
Sponsored Links
Advertisement
  #12
Old 04-02-12, 19:21
cox4720's Avatar
cox4720 cox4720 is offline
Van Jedi
Quote:
Originally Posted by Vandy Andy View Post
mines done it too. job for tomorrow new cables!
me to mate and atyeo hahaha ive just disconnected the cable on the passenger side for now
  #13
Old 04-02-12, 20:23
Bonzey's Avatar
Bonzey Bonzey is offline
Van Master Jedi
I Support CLIC Sargent
Me to. up the road!
Only got my van on thursday, gave it a wash on friday, went to put it on the drive today and the o/s rear break seemed to be binding when reversing.
Bonzey in Baldock.
Sponsored Links
Advertisement
  #14
Old 05-02-12, 14:17
bighook bighook is offline
Van Jedi
Smile Re: FroZen Brakes
I had the same problem,I reversed out of my drive put it in first and then I felt the dragging then all of a sudden it freed itself and has been ok since, I will inspect the cable when it gets a little warmer and replace if needed,regards bighook.
  #15
Old 05-02-12, 15:11
tatorst5's Avatar
tatorst5 tatorst5 is offline
Van Jedi
glad im not the only not to make it to work on thusday morning, froze solid. wheels off, wd40 and grease out, good wire brush and clean up, wd40 everthing in sight, slap some grease on. wheels back on and off to work for 1pm. interesting that it could be the cables tho, never mind. next time i'll just go back to bed till it thaws a bit.
  #16
Old 05-02-12, 17:51
zand zand is offline
Van Jedi
Yep mine had frozen as well. If leave handbrake off would it not just freeze in the off position?
  #17
Old 07-02-12, 11:02
NiSk NiSk is offline
Van Jedi
Quote:
Yes, but you can exert considerably more force with the handbrake lever than the return spring on the brake caliper!
//NiSk
  #18
Old 07-02-12, 16:12
templar templar is offline
Van Rookie
the retractor spring underneath on cable to rear is either broken or needs replacing and adjusting . ok.
templar.
  #19
Old 07-02-12, 16:43
Grey,n Grumpy Grey,n Grumpy is offline
Serial Poster
I regularly use a garden pressure spray on all underbits , with diluted Waxoyl , or similar , on all cables , linkages , etc . and have never had this issue ... !! I have a 94 . 2.4 LWB and have owned it sice July , 94 . Even last year in -15 , no prob ... !!
  #20
Old 07-02-12, 21:18
Van Jedi
Quote:
The wife's '69 MGB GT has grease nipples on the handbrake cables - why don't they still fit these? Would solve a lot of problems (but maybe sell a lot less handbrake cables!https://www.vwt4forum.co.uk/images/smilies/biggrin.gif)
//NiSk
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
