Reply
Thread Tools Display Modes
  #41
Old 16-01-18, 09:51
defever defever is offline
Van Jedi
Default Re: FroZen Brakes
Update on this.
I got a pair of Pagid handbrake cables from EuroCarParts (make sure you check if you've got disc or drum brakes at the rear and check the length of the cable assording to SWB or LWB!) for 10 (50% flash sale code!).
Followed this instruction on how to replace them:
VWt Magazine: Replacing handbrake cables on a Volkswagen T4
It's straight forward, theoretically. But the old cables were completely seized at the disc brake actuating levers end and I had to spray WD-40 and a bit of hammer action to break loose. They did eventually come out. The rest is so easy. Upon inspection, there were loads of water inside the cables...
I like the new Pagid cables because the inner steel cable itself is protected by plastic / rubber sleeve (like a heat shrink sleeve) and the outer cable is also covered with the same material. The only part the metals are exposed are the ends. So I rubbed some copper grease on the exposed metal parts (not right on the "z" end hook and the ball end, obviously) and where the clips / brackets hold the cable. For this reason, I wouldn't recommend spraying WD-40 on the new cable (WD-40 will eat rubber / plastic in no time)
Another job well done. I won't have to worry about handbrakes hopefully for a long time!
Happy motoring!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
