Reply
Thread Tools Display Modes
  #151
Old 25-08-16, 16:01
Rake's Avatar
Rake Rake is offline
07415125940
I Support CLIC SargentI Support Children In NeedOfficial TraderVW Transporter
Default Re: Project Power
Quote:
Originally Posted by candikid View Post
I've read through this and the original PP1 thread without finding anywhere to actually order the nozzles...? Is it based on forum PMs?
I have one concern: I live in Norway, and obviously don't have the opportunity to go to UK to get a remap. Rake: Do you have any suggestions on what to do? It's a 97, so I take it it needs new chips soldered on too.
Do you reckon I can fit the new nozzles and then get a remap from any VW tuner here in Norway, of course one that tunes the actual ECU and no piggyback box or anything...?
Hi candikid,
I would suggest that you contact the local mappers prior to ordering to confirm that they can indeed perform the chip solder work and map to oversized nozzles. We have had a fair few NO customers so I am sure this is possible.
Kind regards.
Ron.
Sponsored Links
Advertisement
  #152
Old 13-03-17, 17:14
Fightingtorque's Avatar
Fightingtorque Fightingtorque is offline
Van Man
Another positive experience for the PP injectors. I have a Y reg 102 Caravelle which hasn't run right since I got it - it had diesel knock under load, power wasn't impressive either.
Admittedly I discovered a couple of things whilst changing the injectors - I had definitely been missing one of the pillars that goes under the other end of the injector clamp, and that injector showed some evidence of blowby because of this. I also think that one of the injectors was missing it's copper seal, but it is possible I dropped it as I was removing it and didn't realise. Finally, one of the specially shaped washers that sit under the injector clamp bolt was missing.
Knocked up replacements for the missing pillar and washer in my lathe.
Aside from that, changing them is fairly easy, I didn't remove the radiator, just took the top part of the grille off and the crossmember and tilted the rad forward to the service position. And of course you have to drop the undertray to get at the connector for the lift sensing injector. Little bit fiddly in parts and having a magnet tool on a stick helps avoiding dropping the bits.
I've only been out on one short trip with it so far, but it was immediately evident that it is totally transformed, with more power at all points in the rev range, no smoke and still with a nice smooth idle.
So thanks very much Ron/Rake/Project Power!
Gav
  #153
Old 20-07-18, 10:13
Rake's Avatar
07415125940
Recent feedback about PP1's here -
https://www.vwt4forum.co.uk/showpost...87&postcount=1
Sponsored Links
Advertisement
  #154
Old 21-08-18, 22:20
Hinny Hinny is offline
Van Man
Hey Rake, could you PM me the price for a set of injectors for PP2 please?
Cheers,
  #155
Old 26-09-18, 18:14
dustdormand dustdormand is offline
Van Rookie
Hi Rake,
Can you PM price for PP0.5 injectors please? 2.5tdi ACV 102
Can you just supply nozzles? or is it the full setup?
Thanks.
Reply
Tags
project power, tdi tuning
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
project power mpg paul ss General Van Chat 16 02-05-11 20:50
who needs project power .......... the Green Geko General Van Chat 5 11-02-09 18:42
Project Power T4Tasty Engine & Gearbox 6 19-08-08 15:14
1.9td project power (68 bhp) golfgtioz Engine & Gearbox 19 19-05-08 18:46
Project power orangevanman Engine & Gearbox 1 18-03-08 20:47
