Reply
Thread Tools Display Modes
  #11
Old 23-06-12, 21:57
Rake's Avatar
Rake Rake is offline
07415125940
I Support CLIC SargentI Support Children In NeedOfficial TraderVW Transporter
Default Re: 2.5 TDi timing scattered / unstable timing - this isnt a "how do you time TDi" po
I would. Heck the injector resistance pin to pin and also pin to ground (injector body)
Let me know the readings both hot and cold.
That fuel temp is a clue. When these go they make the timing unstable. I lay odds that it's the temp sensor in the pump.
I would be very surprised if the injectors are the problem.
Sponsored Links
Advertisement
  #12
Old 24-06-12, 23:14
sirweste sirweste is offline
Van Jedi
Cheers for the advice gents. Been out riding my bikes rather than crawling around under the van for once!!
So when I arrived in Shropshire today I took a picture of every page of vagcom!
I'm so convinced that this isn't fuel pump related! It's just too unlikely that two different pumps have this exact same, fairly unusual, problem.
As you can see the read outs on the measurings blocks the rule temp is more reasonable.
The hot/warm reading for the sensor injector was around 115 ohms.
Cheers again for the help, much appreciated
Ryan
  #13
Old 25-06-12, 05:37
jets jets is offline
Lord of the T4s
My thoughts are that the engine needs to be above 85C, well it does for timing reading.
I wasn't able to download video so maybe you had it up to temp. for those readings.
Sponsored Links
Advertisement
  #14
Old 25-06-12, 07:02
Van Jedi
Right I'm gonna sort out the coolant temp sensor commectioms this week.
Take it from there.
The engine was up to temp, either way it wouldn't effect my symptoms.
Can everyone else see the vid??
  #15
Old 25-06-12, 09:11
Rake's Avatar
07415125940
Your fuel temp is way off in the vag scope screen.
Choose to ignore if you like but this is exactly the symptoms of the fuel temp sensor in the pump fella.
MAF is off too.
Pot 4 injector not good either - deviation of 2.5 and the injector is duff.
Engine has to be at 90 to take readings.
Coolant temp seems ok.
  #16
Old 25-06-12, 14:02
Van Jedi
Two threads is gonna get confusing!!
I'll start off by saying that the poor fella has covered over 320000 miles now so there's bound to be some tired parts!!
MAF sensor the same erratic timing is produced with it disconnected
Will disconnect fuel pumP sensor soon and see if that could be causing it.
Coolant temp seemed a little low to me, but then I assume diesel run cooler than my a-series used to.
Don't know if I said this or not but disconnecting the sensor injector stops the scattered erratic timin, though I assume this is expected as the reading from that injector is one of the things used tO plot points on the graph?
  #17
Old 25-06-12, 17:18
Rake's Avatar
07415125940
The NMS tells the pump and ECU where the commencement of injection is so yes it is possible as its part of the chain.
Did you get the readings I suggested from it ?
Need to get that fuel temp on vagscope again. It did say 132 degrees....not F was it ?
Also known as the G81, this sensor has a direct effect on start of injection.
A bad sensor can make your timing unstable.
(this is not my hand !)
  #18
Old 25-06-12, 20:24
Van Jedi
Cheers, been working On the bike tOnight, so not had anytime to check out.
Will try to find some time to get on it tomorrow. Hate taking the figgin belly pan off!!
  #19
Old 25-06-12, 20:32
Rake's Avatar
07415125940
Keep it off till fixed
  #20
Old 25-06-12, 20:56
dombandit dombandit is offline
Van Guru
ive got same issues
have found a problem broken wire in loom above rocker cover
very small black and white wire looked ok untill i pulled it lightly
but i think because it was broken it causes the temp sensors to brake
waiting for a delivery from gsf
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
