Reply
Thread Tools Display Modes
  #21
Old 01-08-12, 12:37
Brookster's Avatar
Brookster Brookster is offline
Serial Poster
Official MemberVW Transporter
Default Re: 6-speed Conversion kit
Quote:
Originally Posted by Noo Noo View Post
Is a DMF the way to go here Motters? Just aware of the troubles that Brookster had with his.
Fair play. As I've said there's a few that will be interested, me included. Please keep us all up to date.
I've done over 1000miles on the Single Mass Flywheel now and its much better to drive than the DMF
I've had 3 LUK DMF's go on me , one which went big style.
T4 SWB 2.4D Turbo
Sponsored Links
Advertisement
  #22
Old 01-08-12, 16:47
Motters's Avatar
Motters Motters is offline
Van Master Jedi
I Support CLIC Sargent
Fair enough Brookster - but I assume you are running a 2.4D from your post signature which is not the same engine, gearbox, clutch or DMF as the AJT that I have based this thread around?
The modified Sachs clutch I have is also designed to be used in cojunction with a standard DMF. You can of course go down the VR6 clutch and SMF option but this is not the choice I have made after weighing up the options available and driving characteristics of each setup.
The kit has been ordered so I should see it arrive in 2-3weeks now.....will post pictures when I get it in my hands!
  #23
Old 01-08-12, 18:52
tonic's Avatar
tonic tonic is offline
Serial Poster
be interesting to see the results of this! definetly would like this on my set up
Sponsored Links
Advertisement
  #24
Old 01-08-12, 19:00
Zmok's Avatar
Zmok Zmok is offline
Serial Poster
Ive got a sachs single mass in my camper and a dmf in my work van - both 150bhp AJT - both recently changed.
My work van slips a bit now and then but is a bit quieter at idle
My camper does not slip at all and ive been across europe in it twice no problems
  #25
Old 01-08-12, 19:10
Brookster's Avatar
Serial Poster
Quote:
I'd delete that statement if i was you , due to it being incorrect
when you fit the 6 Speed conversion the longer ratio's will put for strain on the DMF Flywheel
how do i know this , cos i had a Quaife six speed conversion in an 02C Box in a Golf
probably the reason 2 of my friend who i go racing with have fitted 228mm SMF form a AJA /AAB and a uprate friction plate (6 puk) in their AJT's which are over 150bhp
T4 SWB 2.4D Turbo
  #26
Old 01-08-12, 22:47
Motters's Avatar
Van Master Jedi
Brookster - it was a question not a statement.........hence the question mark. Maybe I should have worded it differently, but not everyone is perfect!
  #27
Old 02-08-12, 07:02
Brookster's Avatar
Serial Poster
i wouldn't spend the money on the 6 speed conversion for a T4 , better off fittinng a Longer 5th Gear and bigger Tyres etc
T4 SWB 2.4D Turbo
  #28
Old 02-08-12, 10:12
Phatty Phatty is offline
Lord of the T4s
Totally agree, complete waste of money on a van.
Why you'd want 6 gears on a torquey diesel is beyond me.
  #29
Old 02-08-12, 14:49
Motters's Avatar
Van Master Jedi
Who would want a longer 6th gear - Well I would as it happens, the ability to sit at 70mph running approx 2300rpm will greatly improve the long distance motorway driving in the van by reducing engine noise and overall cabin comfort. A slight improvement in MPG will likely eb seen but is not the reason I am carrying out this mod.
If you don't want to spend the money fair enough.......that is your choice. My van is not something I am doing to run for a year and sell, therefore any money spent on it is a long term outlay.......this is a motor I will keep and run alongside other cars for everyday use around town.
As for the longer 5th that is definetly an option, but the downside being that you get a slightly longer step down in rpm between 4th and 5th.....where as the 6th speed kit keeps the standard steps between 1st and 5th whilst adding a similar step down to the new 6th gear. This also comes in very handy on the german autobahns as it will let the van run along at 100mph (at approx 3600rpm) without the engine crying in vain (like present at approx 4200rpm).
I am not arguing a point as to why you should all do this mod, but rather providing information to others who may wish to carry out this as well.
If you don't want to know my findings/experience with the mods I have/am currently carried out it's simple, just don't read my threads.......don't berate and argue that your mods are best, your opinion counts more, etc. That is not constructive to anyone.
Sorry for the rant, but I am seeing this more and more on the forum these days, making this a minefield of information/mis-information rather than the friendly source it has been in the past.
Peace and Love to all.
  #30
Old 02-08-12, 14:59
Lord of the T4s
Incorrect again. and youre ar$ey attitude really doesn't add any weight to your argument at all.
The reason you'd fit a 6 speed kit is to get less of a drop between gear changes so your vehicle stays within it's power band and thus accelerates quicker.
If all you're changing is 5th and 6th then all that is is basically an overdrive kit, and you're then going to have the problem where 4th to 5th is too short if you're not changing the other gears. So you're not fixing the issue you describe with fitting just a longer 5th.
Cheaper and easier to fit bigger tyres and/or change the final drive.
Enjoy your purchase. I love my close ratio 6 speed dog box, but it's not in my T4.....
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
