Reply
Thread Tools Display Modes
  #11
Old 21-06-09, 22:07
Jim Doodle's Avatar
Jim Doodle Jim Doodle is offline
VWT4 Forum Administrator
I Support MacmillanI Support CLIC SargentI Support Cancer Research UKI Support Children In NeedOfficial MemberVW Transporter
Default Re: Automatic Gearbox - Additional cooling
I know i am posting to myself here, but hopefully it will help some others in the long term.
The problem with the radiator with no fan assistance is that the gearbox tends to overheat when it is on steep climb when it has to shift down, and is usually travelling slowly at this point hence there is no airflow over the cooler so the temperature still climb to high.
Hence i think the fan assisted option is the best
Sponsored Links
Advertisement
  #12
Old 21-06-09, 23:15
Jim Doodle's Avatar
In addition to the additional cooling lots of people seem to add an oil temperature gauge/sensor, this would definitely be needed if you were adding a fan controlled unit.
As i see you can either have it inline where you will mount the additional tubing for the coller or make a sensor for the sump, like the following.
Inline oil sensor
http://www.coolairvw.co.uk/ca/3764/m...ch/pid/6555041
Sump oil sensor
Sump oil sensor2
  #13
Old 21-06-09, 23:23
Jim Doodle's Avatar
See attachment for the sonnax adapter kit for additional cooling
This attaches to the banjo bolts which holds the original cooler.
Banjo Bolts
Sonnax Adapters
Banjo bolt close up being screwed in
http://www.sonnax.com/part_summary.p...=3&make=5&unit
File Type: pdf Automatic-gearbox-Adapter Kit installation.pdf (206.5 KB, 197 views)
Sponsored Links
Advertisement
  #14
Old 21-06-09, 23:35
Jim Doodle's Avatar
Here is a nice oil cooler:
Mesa Maxi-Cool 6 Pass External Oil Cooler with fan
http://www.coolairvw.co.uk/ca/3764/m...an/pid/6558090
If you combine this switch temp with this cooler it automatically cuts in at 180, which sounds about right.
Quote:
Designed to be mounted in-line or attaches directly to the Mesa style oil coolers. Automatically operated the oil cooler fan at 180 degrees.
  #15
Old 22-06-09, 06:36
blacktop's Avatar
blacktop blacktop is offline
Van Jedi
Some very useful info here Jim. You are the autobox guru.
Having just bought an auto caravelle,I'm very interested in fitting this mod. Those Sonnax fittings look to be ideal,couldn't find a price on their website though Keep the info coming as I'm definitley going to fit a cooler.
Cheers, Alan.
Present: 2000 SWB Caravelle 2.5 TDI 102HP auto
Past: 2002 SWB Caravelle 2.5 TDI 88HP R.I.P
  #16
Old 22-06-09, 22:24
Jim Doodle's Avatar
The optimal temperature for the gearbox is between 160F to 180F, the water cooling unit runs water from the rad, which is up to 190F, go figure...
  #17
Old 23-06-09, 06:43
blacktop's Avatar
Van Jedi
Quote:
And I thought german engineering was supposed to be among the best. More like an oil heater rather than a cooler!
  #18
Old 23-06-09, 08:47
Jim Doodle's Avatar
That's interesting you mention that German engineering is better, because after they added the lock-up torque convector in 1994 the unit was manufactured in Mexico...
And it was the lock-up convector that has been blamed in the past for the high-temperatures
I would love to hear if anyone has had any problems with the pre 94 automatic gearbox?
  #19
Old 23-06-09, 13:18
gravitykid gravitykid is offline
Van Man
Jim
I love all your info on Auto-Boxes, it's all very useful.
A while back I was having problems with my Auto-box.
After a fluid change the van ran great, but it was only a matter of a few months before it started playing up.
I had suspicions that the ATF was getting too hot and degrading too quickly. So, I rigged up the VAG-COM and went out for a drive to monitor the Auto-Box temp. I was a tad shocked when I discovered that it took no time at all to get the fluid up to 120C (250F) and went as high as 140C (280F)!!! Ok, I reckon the temperature sensor might be a bit dodgy, but the readings were still a cause for concern.
So, I did a bit of trawling on the web and came across a few suggestions:
  1. Fit an oil cooler.
  2. Use a synthetic ATF.
  3. Adjust the torque converter solenoid by winding it in an extra 1/4-1/3 of a turn. (This apparently compensates for wear, reducing the amount of fluid being cut-up in the torque converter, keeping the fluid cooler.)
Out of these 3 I went for the Synthetic ATF.
(Fitting an oil cooler was a bit of an expense and I was a bit nervous about adjusting the torque converter solenoid.)
Anyway, I changed to Amsoil Synthetic ATF.
According to their website it's suitable for the T4 and it handles temperature far better than non-synthetic fluids.
That was about two years ago (15,000 miles) and the van has ran fine. I must admit that the van was not as smooth as with the genuine VW fluid, but it wasn't bad. If anything it seemed a bit more positive.
I still think that the cooler has to be worth a go, so when I get funds released from the missus I'll definitely give it a go. Think I'll leave off the fan and shut off valve though.
I'd also love to do the full Sonnax solenoid mod that you had a thread on while back, just not sure that I'll ever get round to it.
G
  #20
Old 23-06-09, 13:36
Jim Doodle's Avatar
Those temps are crazy! The Sensor for the oil temp through the Vagcom is located in the torque converter itself, so gives a very good readout on not only the oil temperature but the actual compenent temperature.
You could hook up the relay is you were a bit of a boffin on this sensor, but that kind of wizardry would cost time and money.
There is a unit called the "scangaugeII" which is a great gadget for hooking up and getting all sorts of codes etc, including oil sensors, not bad money either Price: 158
http://www.scangauge2.co.uk/
Reply
Tags
automatic gearbox, automatic transmission
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
HOW TO - Change Automatic Transmission Fluid (ATF) photoguide. Jim Doodle Technical Articles 16 15-06-19 14:45
Automatic gearbox woes again Jim Doodle General T4 Chat 26 03-12-10 07:53
T4 Automatic gearbox oil change t4bam Welcome to The VW T4 Forums 4 05-09-08 18:31
Automatic Gearbox Wanted triggerhippy Wanted 3 31-08-08 08:42
Automatic Gearbox Scally General T4 Chat 1 15-01-08 19:16
