Reply
Thread Tools Display Modes
  #21
Old 23-06-09, 16:06
ahay!'s Avatar
ahay! ahay! is offline
More than a little van obsessed
International CoordinatorI Support Cancer Research UKRegional Coordinator
Default Re: Automatic Gearbox - Additional cooling
Slightly off topic sorry but................
Jim I looked at those scangauges before and I was under the impression that they wouldn't work on a pre 2000 van, but yours is pre 2000 isn't it
Gucken Gemien In Friesan Grun........ Mit Nieder
Sponsored Links
Advertisement
  #22
Old 23-06-09, 16:30
Jim Doodle's Avatar
Jim Doodle Jim Doodle is offline
VWT4 Forum Administrator
I Support MacmillanI Support CLIC SargentI Support Cancer Research UKI Support Children In NeedOfficial MemberVW Transporter
It uses the OBDII connector which isn't on any vans pre 1996 they used the OBD (obd1), i was hoping mine might be a different as it is a 95 but it has the on-board computer thing which track temperatures, MPG, trips etc, I have to check mine when i get in.
Here's hoping...
  #23
Old 25-06-09, 00:53
Jim Doodle's Avatar
Default Re: How much room in front of the radiator?
Cheers will, do you think the above cooler would fit in the shortnose?
155 x 585 x 19 mm
Sponsored Links
Advertisement
  #24
Old 25-06-09, 11:29
Jim Doodle's Avatar
That cooler is near impossible to source in the UK without payment shipping and import from the US,
So been lookgin for other potential donnors, and cam eup with the Oil-Cooler from the VW Touareg.
This one is bigger still, but at least i can get it in the UK, might be a little too wide though have to check when i get back.
Overall size is :655 X 160 X 16 mm
That is without the fixing tabs, which could probably be altered
  #25
Old 25-06-09, 20:03
Jim Doodle's Avatar
I've been out looking in my neighbours Audi Q7 which has the same cooler as above, Main dealer price 300 ish, so this no0n-oem seemed pretty good steal at 186.
Right the measure up seems like it will fit, so i order it, fingers crossed
http://www.aaronradiator.co.uk/produ...05-5079-0.html
  #26
Old 26-06-09, 06:30
blacktop's Avatar
blacktop blacktop is offline
Van Jedi
Good luck Jim, keep us all posted how you get on. I'm looking at doing this mod to lengthen the life of my auto too.
Alan.
Present: 2000 SWB Caravelle 2.5 TDI 102HP auto
Past: 2002 SWB Caravelle 2.5 TDI 88HP R.I.P
  #27
Old 26-06-09, 15:08
Jim Doodle's Avatar
I just ordered the cooler adapter:
Part Number: 119814-01K
Automatic Choice England
Radstock
Bath
01761-436688
Quoted 80, instock
VM Transmission Products Ltd.
Hayes
Middlesex
0208-848-9911
Quoted 30 ish, outstock, put on order
  #28
Old 26-06-09, 15:34
Jim Doodle's Avatar
change if plan, the parts on order will take 2 weeks at least to come in so order from another place
JPat
nits 4a & 4b Pear Tree Industrial Estate
Upper Langford
BS40 5DJ
UK: 0845 130 4754
Quote: 70 something
should arrive Monday same day as the cooler!
  #29
Old 26-06-09, 22:00
blacktop's Avatar
Van Jedi
What exactly is the cooler adapter?.
  #30
Old 27-06-09, 12:40
Jim Doodle's Avatar
The sonnax adapter kit which allow you to reroute the oil from the existing cooler to an external one.
Posted some info about it up there a bit
https://www.vwt4forum.co.uk/showpost....0&postcount=12
I thought they would be cheaper TBH as the ones online form the states are half that price, might be worth getting them over there and shipping over, they are only a small item, they might even skip under the import duty radar if they are really small.
Reply
Tags
automatic gearbox, automatic transmission
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
HOW TO - Change Automatic Transmission Fluid (ATF) photoguide. Jim Doodle Technical Articles 16 15-06-19 14:45
Automatic gearbox woes again Jim Doodle General T4 Chat 26 03-12-10 07:53
T4 Automatic gearbox oil change t4bam Welcome to The VW T4 Forums 4 05-09-08 18:31
Automatic Gearbox Wanted triggerhippy Wanted 3 31-08-08 08:42
Automatic Gearbox Scally General T4 Chat 1 15-01-08 19:16
