Reply
Thread Tools Display Modes
  #251
Old 05-12-08, 16:33
paul ss's Avatar
paul ss paul ss is offline
Serial Poster
Default Re: 1.9 PP thread
egt gauges are good in my opinion , they tell you a lot about what your engine is doing if you actualy no what to look out for .
a decent egt gauge is not going to be cheap though i am planing to run a sard egt gauge on mine when i ever get time and my van back i will try get time to do it but not realy instrested in tunning a engine that is never going to make power so ma not bother .
only acruate way of getting a reading is to have 4 individual probes in each runner , some pepole tap the turbo to mount one but there called egt for a reason and only true way of getting good reading .
there not cheap though for a decent one and the one i have saved my car engine on numrous ocashions , **** me right up though when on 2.4bar boost and blew every probe out the manifold down to presure and started flashing red and alarm going i got worried and was on motorway at time with no hard shoulders
Sponsored Links
Advertisement
  #252
Old 16-03-09, 02:06
chris_gla chris_gla is offline
Van Rookie
Found an EGT kit for 28 at http://www.mcgillmotorsports.co.uk/i...d&productId=35, they also have matching boost gauge for 23.
Googling the p/no LED 52708WH they seem to be made by Ruian Kangertai Automobile Parts Co., Ltd.... never heard of them and not much else on the net!
Wondered if there was any way to use the fuel/ air ratio meters they have to improve max fuel setup?
  #253
Old 16-03-09, 19:01
John J M John J M is offline
Van Master Jedi
All this power talk ! have people forgot theyre driving a 2ton van? chill...cruise on by a little....take it easy!. Saying that, I decatted mine blocked the EGR...average....then removed the vac hose and blocked both ends after making sure the valve was shut and bingo! it goes like a cut cat....but i still prefer to cruise
Sponsored Links
Advertisement
  #254
Old 17-03-09, 19:57
Van Rookie
it's not the swooshing I want it for...it's just a bit of a pain when you're going up and down some hills... particularly Northern Scotland.
Worst I had was being stuck behind a Range Rover pulling a caravan... I'd struggle to keep up 40 or so going up the hills- he had no probs. Then going down he'd have to slow down for control whereas I wanted a wee bit of speed to get back up the other side!
Don't need to go for the 2.5 but the extra boost from upping fuel and increasing boost has made a big difference... all I need now is the EGT gauge to see if I'm cooking the engine!
Still looking at/ considering the intercooler, removing cat isn't on cards for now as I put a new exhaust on about 2 years ago.
Has anyone fitted an exhaust gas temp gauge? The turbo gauge was easy but I take it I need to drill the manifold between the engine and turbo to fit this? Bought an oil temp gauge to go with it for extra safety....!
  #255
Old 18-03-09, 22:41
Van Rookie
Has anyone fitted an EGT gauge and if so where did you put the pyrometer probe?
s'pose it's too much to expect a pre-drilled hole on the turbo inlet...
  #256
Old 18-03-09, 23:17
paul ss's Avatar
Serial Poster
the probe wants fitting into one of the runners on the manifold or turbo tapping ,
which ever make sure the part is removed from the engine and no steel shavings go into the turbo or engine .
  #257
Old 19-03-09, 07:56
pearly whites's Avatar
pearly whites pearly whites is offline
Lord of the T4s
you guys are great ive taken every thing in and jobs a gooden shes a flyer
  #258
Old 10-03-16, 07:14
denking denking is offline
Van Guru
Official MemberVW Transporter
T4 Post Icon Re: 1.9 PP thread
Quote:
Originally Posted by crftom View Post
project power is nearly finish ive finally upped the boost and fueling on my 1.9td after reading loads of posts on pug 306 td tuning forums and them saying how easy it was i decided not to pay 175 pounds for somone else to do it, i pritty much follow there instructions increasing the max fuel screw 20 degrees at a time until a small amount a of black smoke off turbo can be seen, then upped the boost on the turbo by shortening the actuator arm by about 5m from 10 psi to 15psi
it drives so much better, it will now pull from 50mph in fifth gear up hill
almost feels like driving a 2.5tdi, iam well pleased with the outcome
tom
Mine is a VWT4 1.9TD 1997 Tom. Just had it Terracleaned and it helps a lot. Can I do the same things you done to mine and will it make a difference?
Reply
Tags
1.9td tuning
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
that 'best thread' thread got me thinking... leviticus18_23 General T4 Chat 4 08-12-11 13:48
EGR thread - where's it gone? Gasman Engine & Gearbox 43 10-03-09 16:06
The VW MAN Thread StephenTazz T4 Articles & Information 10 01-02-09 16:20
Another how much thread Transpunter General Technical 5 04-02-08 16:20
