Thread Tools Display Modes
Old 23-06-11, 15:30
Split Charging DIY Kit
Xtremevan Xtremevan is offline 23-06-11, 15:30
Following many requests from you guys that like playing with vehicle electrics, we have decided to make use of some 100 amp relays that we have tucked away. By adding extra parts we are able to offer a 'Budget' DIY Split Charging Kit that is unique to forum members. This kit contains everything that is required, including 110amp 16mm cable (5 mtrs), 100amp (Nagares RL/180-12) relay, cable ties, fuse holders & fuses etc, etc plus full easy to follow fitting instructions and advice at the end of a phone if needed.
Price 50.00 delivered to your door
If you require and more details / advice - please just give us a shout.
Can be purchased via the link below:
http://www.xtremevan.co.uk/product_i...oducts_id=5199
Please not this in NOT suitable for newer vehicles with inteligent alternators... Bear with us on this, we are figuring it out! - please see progress below
Just to update this post regarding the inteligent alternators, which we have listed above:
As we have yet had the opportunity to investigate this Black/Yellow wire at the fuse box I would suggest that the following checks are done on this wire before using it to trigger the split charge relay:
1. This wire is 0 volts with the ignition switch in the off position.
2. This wire is 12 volts with the ignition switch in the on position.
3. This wire is 0 volts in the starter motor cranking position.
Alternatively if your vehicle is fitted with the earlier type "non intelligent" alternator, connection to the Blue wire at the alternator will provide a trigger for the split charge relay.
It is also worth mentioning that an additional low powered (VSR) Voltage sensing relay, such as the "Smart Com", may be used to trigger the larger split charging relay, this can be connected to the vehicle battery via a fuse and then the output onto the 100 Amp split charging relay supplied with the kit.
Many thanks
Jay
Xtremevan's Avatar
Xtremevan
Trade Member Plus
Quick reply to this message
  #91
Old 04-01-12, 08:28
conners t5's Avatar
conners t5 conners t5 is offline
Van Guru
Default Re: Split Charging DIY Kit
thanks for that
Sponsored Links
Advertisement
  #92
Old 05-01-12, 19:33
Xtremevan's Avatar
Trade Member Plus
Quote:
Originally Posted by conners t5 View Post
thanks for that
no worries dude
  #93
Old 07-01-12, 08:30
Xtremevan's Avatar
Trade Member Plus
This offer will also be running until the end of Feb
many thanks
Jay
Sponsored Links
Advertisement
  #94
Old 07-01-12, 08:49
Hobbsy's Avatar
Hobbsy Hobbsy is offline
Lord of the T4s
Ill have one, where does the 5m cable get you as i was hoping to place mine near the middle of the rear of van behind driver?
  #95
Old 07-01-12, 09:56
tatorst5's Avatar
tatorst5 tatorst5 is offline
Van Jedi
just paid for mine via link, nice one , many thanks.
  #96
Old 08-01-12, 08:54
Hobbsy's Avatar
Lord of the T4s
Me too! lets have it
  #97
Old 08-01-12, 09:58
Xtremevan's Avatar
Trade Member Plus
Quote:
Thanks for the order chap, it all depends where you intend to put your leisure battery, but dont worry if you find it doesnt reach just give me a shout and i will sort some more cable out for you
Quote:
No worries thanks for your order and if you need anymore help, just give me a shout
many thanks
jay
  #98
Old 08-01-12, 17:23
commandoclimber commandoclimber is offline
Van Man
Hi Jay
Just wanted to say thankyou for getting a charging kit out to me. I took a couple of hours yesterday to get it fitted and I am now up and running!
I can recommend the DIY kit to anyone thinking of installing a leisure battery as I am neither an electrician or professional 'campervan converter' but found the kit very easy to install.
Thanks again
Steve
  #99
Old 08-01-12, 18:27
Xtremevan's Avatar
Trade Member Plus
Quote:
Originally Posted by commandoclimber View Post
Hi Jay
Thanks again
Steve
hey no worries Steve, just glad to help out many thanks for the feed back and if you need anymore help info etc, just give me a shout dude
many thanks
jay
  #100
Old 16-01-12, 18:03
welshypugh's Avatar
welshypugh welshypugh is offline
Lord of the T4s
T5 Post Icon Re: Split Charging DIY Kit
Hi guys, I'm looking for a complete kit for a 57 plate t5.. Don't know exactly what I need.. Can you suggest all the parts I need . Just want to run some lights and one socket of it.. Don't know what's involved or the costs? Am interested in your kit. Apart from the obvious battery can you supply the switches and sockets etc.. Thanks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
