Thread Tools Display Modes
Old 23-06-11, 15:30
Split Charging DIY Kit
Xtremevan Xtremevan is offline 23-06-11, 15:30
Following many requests from you guys that like playing with vehicle electrics, we have decided to make use of some 100 amp relays that we have tucked away. By adding extra parts we are able to offer a 'Budget' DIY Split Charging Kit that is unique to forum members. This kit contains everything that is required, including 110amp 16mm cable (5 mtrs), 100amp (Nagares RL/180-12) relay, cable ties, fuse holders & fuses etc, etc plus full easy to follow fitting instructions and advice at the end of a phone if needed.
Price 50.00 delivered to your door
If you require and more details / advice - please just give us a shout.
Can be purchased via the link below:
http://www.xtremevan.co.uk/product_i...oducts_id=5199
Please not this in NOT suitable for newer vehicles with inteligent alternators... Bear with us on this, we are figuring it out! - please see progress below
Just to update this post regarding the inteligent alternators, which we have listed above:
As we have yet had the opportunity to investigate this Black/Yellow wire at the fuse box I would suggest that the following checks are done on this wire before using it to trigger the split charge relay:
1. This wire is 0 volts with the ignition switch in the off position.
2. This wire is 12 volts with the ignition switch in the on position.
3. This wire is 0 volts in the starter motor cranking position.
Alternatively if your vehicle is fitted with the earlier type "non intelligent" alternator, connection to the Blue wire at the alternator will provide a trigger for the split charge relay.
It is also worth mentioning that an additional low powered (VSR) Voltage sensing relay, such as the "Smart Com", may be used to trigger the larger split charging relay, this can be connected to the vehicle battery via a fuse and then the output onto the 100 Amp split charging relay supplied with the kit.
Many thanks
Jay
Xtremevan's Avatar
Xtremevan
Trade Member Plus
Quick reply to this message
  #101
Old 16-01-12, 19:31
Xtremevan's Avatar
Trade Member Plus
Default Re: Split Charging DIY Kit
Quote:
Originally Posted by welshypugh View Post
Hi guys, I'm looking for a complete kit for a 57 plate t5.. Don't know exactly what I need.. Can you suggest all the parts I need . Just want to run some lights and one socket of it.. Don't know what's involved or the costs? Am interested in your kit. Apart from the obvious battery can you supply the switches and sockets etc.. Thanks
Hi, thanks for your intrest, we have a couple of options, the first being the DIY kit in this thread, which allows you to have a split charge system set up for charging your leisure battery, you would then have to add fuses for each circuit from this, or the other option is the heavy duty split charge system that has everything built into it and is a very easy plug and play system.
Please find the link to this below:
http://www.xtremevan.co.uk/product_i...oducts_id=5026
Its all down to what you want it to do, how much time you want to spend on doing it and of course how much you want to spend
If you would like me to send you the full fitting instructions for both of these, just drop me a pm with your email address and i will fire them accross - the heavy duty split charge has a copy of the instructions on our website
Many thanks
jay
Sponsored Links
Advertisement
  #102
Old 17-01-12, 07:42
welshypugh's Avatar
welshypugh welshypugh is offline
Lord of the T4s
T5 Post Icon Re: Split Charging DIY Kit
Thanks jay. I've sent you a pm with my email.. Any info advice etc would be great.. As I need to pull my finger out and start work on the van!
  #103
Old 17-01-12, 08:12
Xtremevan's Avatar
Trade Member Plus
Hi Chris, got your email chap, but it keeps bouncing back, ive also sent you a pm explaining this - we will get you sorted
Many thanks
Jay
Sponsored Links
Advertisement
  #104
Old 17-01-12, 20:19
DazF's Avatar
DazF DazF is offline
Van Guru
Just like to say, I have finally got round to fitting mine today
Top quality kit, easy to follow instructions.
Took me around 1 1/2 hours in total to install.
Regards
Daz
  #105
Old 17-01-12, 20:29
Xtremevan's Avatar
Trade Member Plus
Regards
Daz
Hi Daz,
thanks for the feed back and glad it all went well
many thanks
jay
  #106
Old 17-01-12, 22:18
t5van's Avatar
t5van t5van is offline
Serial Poster
I'm going for the full size monster once me card arrives .. :-( but ordered a 7-20V display from China for reading the volts to go with it.. 6 on it's way..Hurry up Halifax bank!!
  #107
Old 18-01-12, 06:59
Xtremevan's Avatar
Trade Member Plus
Quote:
No Worries, plenty of stock on the shelf to keep up with the demand, and yours is all polished and ready to go
Many thanks
Jay
  #108
Old 20-01-12, 16:39
MrDaz MrDaz is offline
Van Guru
Hi Autospark & anyone else with an opinion on this.
I ordered the heavy duty split charge system a couple of weeks ago, I've been looking at it in the box whilst drinking lots of tea and wondering what the best way is to run the cable from the leisure battery through to the starter battery?
I will be installing the LB under the passenger seat?
Thanks in advance for any advice, a picture tells a thousand words so any pics would be appreciated.
  #109
Old 21-01-12, 14:50
Xtremevan's Avatar
Trade Member Plus
hi chap, someone has put a post on here showing just that, but the best way is along the pass foot well and up behind the dash, you will find a large grommets that you can pop it through and then straight into the battery box - im sure the tread is called heavy duty power dist fitting, i will try and find it for you
many thanks
jay
  #110
Old 21-01-12, 17:58
Van Guru
Quote:
many thanks
jay
Found it.....cheers for the reply!!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
