Reply
Thread Tools Display Modes
  #11
Old 16-11-11, 20:31
Red5's Avatar
Red5 Red5 is offline
previously known as passattdi
T5 Post Icon Re: How to fit Modern VW steering wheel to 99 T4 with spline adapter
Does anyone know if the Passat steering wheel will fit on the T5 too? Also does anyone know what size the splines are?
Sponsored Links
Advertisement
  #12
Old 17-11-11, 19:22
paul20v's Avatar
paul20v paul20v is offline
Serial Poster
Default Re: How to fit Modern VW steering wheel to 99 T4 with spline adapter
Quote:
Originally Posted by Insanity View Post
Well maybe one of us can suss this then mate, I'll let you know if I find out and vice-versa.
will do mate its definately on my todo list
  #13
Old 17-11-11, 19:51
creeriver's Avatar
creeriver creeriver is offline
Van Master Jedi
Ok, does this also include 1995 models or is there a different fitment? I tried swapping the steering wheel from a 1999 but it wouldn't fit the 95 properly?
Gaz
Sponsored Links
Advertisement
  #14
Old 24-01-12, 23:33
fergieterrry1 fergieterrry1 is offline
Van Man
hi just read the thread about the steering wheel,one thing i was wondering does the horn work after fitting or do you have to adapt anything pic would be good if possible
  #15
Old 03-02-12, 18:32
vwbus917's Avatar
vwbus917 vwbus917 is offline
Van Guru
T4 Post Icon Re: How to fit Modern VW steering wheel to 99 T4 with spline adapter
] I tried fitting steering wheel from a seat Leon exactly the same as the passat only I couldn't get the horn to work. The slip ring doesn't have the continuous copper ring like the original so no connection to horn. I have removed the original ring from my old wheel and I'm working on how to fix it to the back of the new one. If this works it will obviously cancel indicators too.
One good thing I did find out is that a lot of the VAG cars had the adaptor pressed onto the steering column. I got one from a scrap yard of a seat cordoba it fit straight onto my small 17mm spline so saved me having to buy the adaptor from vw.
Finally made a few mods and got wheel on with working horn and indications. I had to make up a homemade boss from an old plastic tube I had laying around. Firstly I cut down the tube to fill the gap between the new wheel and the steering column. I fixed the original slip ring to one end of the tube and screwed the other end to the new wheel.
Covered the whole thing in a bit of black leather vinyl to match wheel, then I just reconnected horn wire and job done.
Made up a new decal to cover seat logo on wheel. Everything perfect. Indicators cancel and horn works from wheel.
http://s848.photobucket.com/albums/a...0Modification/
  #16
Old 03-02-12, 20:03
PerkinsEngine's Avatar
PerkinsEngine PerkinsEngine is offline
Serial Poster
Hello N13 LVV,
Like the 35 in the background. The city boys won't be sure what I'm on about.
  #17
Old 03-02-12, 20:56
JefeDeMaquinas's Avatar
JefeDeMaquinas JefeDeMaquinas is offline
Serial Poster
party Re: How to fit Modern VW steering wheel to 99 T4 with spline adapter
Assuming U mean that agricultural motor vehicle often refered to as a tractor
  #18
Old 21-07-12, 17:56
Marsh1707 Marsh1707 is offline
Van Man
Sweet as, but what about the horn??
  #19
Old 27-06-13, 19:52
Honkey Honkey is offline
Van Rookie
One quick question did you get any play in the steering column? It appears that the spline adapter does not splay out like the precious steering wheel.
  #20
Old 19-08-14, 21:56
BarkersT4's Avatar
BarkersT4 BarkersT4 is offline
Van Man
I've found a wheel on eBay and got the spline from tps last question will the horn plug in exactly the same as the two spade connectors on the old wheel?
Reply
Tags
spline adaptor, steering wheel
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
