Reply
Thread Tools Display Modes
Old 20-01-14, 15:51
How To Fit Late Model VW Steering Wheels to Post '96 Vans
snedboy snedboy is offline 20-01-14, 15:51
I though I'd post this as questions about changing steering wheels come up so often
First off to clear up any misunderstanding ALL T4s CAME WITH 17mm SPLINES at the top of the steering column. If you've got 27mm splines on you're steering column then you've already got the adapter fitted
The adapter I used, VW part No. 191 419 514, fits the following vehicles. So in theory steering wheels from these vehicles should fit on your van, if you use the adapter
Polo Mk3 94/01
Golf Mk2 01/88-10/88
Golf Mk3
Golf Mk4
Jetta 01/88-10/88
Scirocco 84-11/88
Corrado 89-95
Caddy 83-88
Skoda Superb 2009
Audi A4
Audi A6
There are plenty of others that fit i just nicked this list off the VW Heritage site. If anyone has a more comprehensive list pm me and I'll add it
I decided to do something about my steering wheel, it had the usual T4 problem of having come unglued from the inner ring.
My mate Richy was breaking a Polo and I liked the look of the wheel so I bought an adapter from VW, it's part No. 191 419 514,
Richy advised me to get rid of the airbag as my van doesn't use one
After removing the airbag I made a cover from hardboard, then sprayed expanding foam in through one of the gaps to fill the cavity. The foam takes the place of the missing airbag so the front of the wheel keeps it's shape
Heres the adapter, should be about a tenner from VW (that part number again 191 419 514)
With the new wheel and adapter fitted this is the gap you're left with
I decided to mate the Polo and T4 horn rings together, after trimming the indicator cancel tab off the Polo ring I screwed and glued the T4 ring to the bottom of the Polo ring (make sure the T4 cancel tab is in the right position) I used the watering can spout to center the two rings.....nice
You can just make out the ends of the three screws holding the two parts together. I tightened the screws until the plastic just started to bend, cut the tips off with side cutters and then unscrewed them 'till they sat flush. Screw through from the T4 ring into the Polo ring
T4 horn wire connected to Polo horn buttons
Now the Polo ring clips to the Polo wheel and the T4 ring connects the horn and cancels the indicators just like it used to. All I need now is a cover to hide it all.
Looking good though it does obscure the dials a wee bit. I'm just glad to see the back of that cack T4 wheel (excellent mod this)
__________________
Wham Cars, Retro Workshop
https://www.facebook.com/WHAMCARSRETRO/?ref=bookmarks
snedboy's Avatar
snedboy
Serial Poster
Regional Coordinator
Re: How To Fit Late Model VW Steering Wheels to Post '96 Vans
20-09-18, 02:08 #11
filmshoot
Van Guru
Oddly enough 191 419 514 keeps giving me a 17to26mm adapter on google.
But I do indeed need a 17to27mm
Also has anyone got their horn and airbag working too in their t4 conversion?
...just tapped out with a thumb or 2, please don't mind the abbreviations and grammatical faults.
Sponsored Links
Advertisement
20-09-18, 07:39 #12
scruffytoo
More than a little van obsessed
The 191 419 514, was just a lucky find for a T4, as it's an original early Caddy and car part. So I guess any variation you may need will also be a lucky find too; unless someone is specifically manufacturing them
scruffytoo's Avatar
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
