Reply
Thread Tools Display Modes
Old 22-01-08, 21:12
HOW TO - Clean and blank your EGR (2.5tdi)
t4trick t4trick is offline 22-01-08, 21:12
Rating: (1 votes - 5.00 average)
taken from the VW T4 Library originally posted by 'T4Trick' on the 19th April 2007
http://vwt4.forumsplace.com/message10996.html
There a quite a few images and so the page loading will be slow.
T4TRICK'S thread
The Definitive EGR cleaning how to
This is everything that you need to know about the EGR. Why we have it, what it is, and how to gain better performance by cleaning it - yes cleaning it makes you go better!
This is also an absolute must if Project Powering. I needs to be done before the injectors and the remap - or you may not gain the full potential of your outlay. (Speaking from experience)
The following is a guide, and only that. Please read the whole article before undergoing any work. It is your own decision and responsibility to carry out any work and the outcome of such work. Please bear in mind that there may be slight variations in models and years.
Apparently, the black gunk is carcinogenic - so protect yourself. You've been warned! Latex gloves are cheap as chips.
Right here we go:
Intake Manifold and EGR Cleaning
This vehicle is equipped with a CCV (crankcase vent) system and an EGR (exhaust gas recirculation) system. Oily fumes from the CCV system can combine with carbon particles from the EGR system to form a black sticky tar in the intake system (pics below). This build up eventually starts restricting the amount of airflow allowed into the engine through the EGR, resulting in gradual power loss as the vehicle ages and the intake clogging becomes worse.
Operating conditions, fuel quality, oil quality, driving habits, and general condition of the engine will all have some effect on how long the intake system survives before clogging up.
So, why do we have it?
The EGR is simply an emissions reducing measure. When the engine heats up excessively, nitrous oxide is produced and this is one of the worst emissions. To reduce this production, the engine temperature needs to be reduced and the EGR allows recirculated exhaust gas back into the inlet side of the engine. This is a continuous process happens more when the engine temp rises and help to reduce the operating temperature.
It does however, to differing degrees, make the engine less efficient and also curbs the maximum performance.
Some EGR applications can have the mapping of the valve changed to reduce the actuation, and others simply choose to block it off. You will see the latter below.
Blocking off is not possible on a petrol engine because of the MOT checks. But this is not the case on diesels and it certainly stops the gunge creation, as long as you are aware that the engine is producing more 'naughty' gasses than it was originally intended to.
OK, here's some idiot guide pics:
Take the inter-cooler (4 nuts) off and associated pipes (spring clips). Also the sensor clips. You may also unbolt the coolant reservoir (two screws) for easier access to the inter-cooler to EGR pipe.
The EGR is the aluminium inlet on top of the engine inlet manifold. The bronze coloured pipe, on top in the pic, is the exhaust inlet into the EGR pipe. Unbolt this (2 bolts) and undo the EGR (4 bolts). There are also vacum hoses to unconnect. Simply pull these off.
The pipes have a slight coating of oil from the CCV which is normal, but look at the EGR internals. They are where the gasses meet. You can see in the second pic, the deposits are far heavier on the outlet side.
Now have a look at the opening to the inlet manifold. Do not try and clean the deposits inside the manifold as you will allow solids to enter the engine. If you want to clean the inlet manifold, then that requires you to fully remove it and go through the cleaning procedure off car. A far bigger job.
To clean the EGR use something that you'll want to throw away. I used an old toothbrush and a stick (you know, the found from a tree type), and a full can of injection and carb cleaner (if you've never used this before, it will surprise you how good it is). Look at what one scrap produced.
And here is the finished article - clean. Looking at the pic, The diaphragm on the left is the EGR which moves by vacum the needle running left to right. This opens the inlet on the right hand wall - letting the exhaust gasses in.
If you want to go down the route of blocking off the EGR port, you need to make a plate to sit between the EGR and the exhaust pipe inlet. Below you can see one made from an old hand saw blade (left), as it is strong and thin. I used two new gaskets on either side of the blanking plate for a good seal.
Now its a case of rebuilding.
Buy new gaskets before you start the job (3). They will cost less than 10. Make sure the mating surfaces are clean, dry and grease free. Be very gentle when cleaning them as the alloy faces are easily marked and this would compromise the sealing ability.
Replacing all of the screws, bolts, nuts and spring clips. Inspect the pipes and be as careful replacing them as you were when taking them off. As they may be weakened in the engine bay heat. Remember to reconnect the sensors. Do not over tighten, as your threading into alloy. You could use a small amount of thread lock also.
The engine may stumble starting for the first time, but should be fine thereafter.
Now, if you blocked off the exhaust recirculatory inlet, enjoy the increased performance. With the miles done after the engine it will self clean the deposits in the inlet manifold and this means that the engine can only get better.
I was 15-20bhp less than others that had Project Powered at the Rolling Road, and this is one of the attributing reasons. That's 10% + of your engine power, not to mention the loss of driving sensation.
I hope this has helped.
T4TRICK
In the original thread other folk posted links to other relevent threads:
http://vwt4.forumsplace.com/message-1323.html
More supporting posts regarding EGR and inlet manifold clean.
http://vwt4.forumsplace.com/message-10428.html
http://vwt4.forumsplace.com/message-7527.html
Quote:
Originally Posted by Brooksie View Post
Nice thread.
It looks a straight forward mod to have a try at.
Will it make much difference then? Would be interested to hear what result people have notice that have done this to their T4's
Brookie - since I posted that thread, many T4ers have added their own info, both on their T4 experiences or from other walks of life, such as commercial garage/fleet mechanics and so on.
Every person had positive additions to the thread. It ran some 10 pages if I remember correctly and most of it was thanks about thier own vehicle. Its a messy job that lasts for the rest of the engine life. Mot's are fine, etc...
All the best, T4trick
t4trick's Avatar
t4trick
Lord of the T4s
I Support CLIC SargentI Support Children In NeedOfficial MemberVW Transporter
Re: HOW TO - Clean and blank your EGR (2.5tdi)
14-03-11, 01:42 #21
joeyg1
Van Expert
I did mine today it was an easy job after reading this post! i found the old 4mm recirculation blanking plate off my old g60 and trimmed that down to fit!
I might be dreaming but it seems to pull smoother up to 2k now?! sweet
Sponsored Links
Advertisement
14-03-11, 15:38 #22
T4newbe
Lord of the T4s
THANKS to T4tricks for a great post ,made it very easy to follow , done mine this morning , just the decat to do , before & after pics
19-03-11, 16:22 #23
burrellefx
add The Burrell on Xbox Live
just done mine for the 1st time
only had the van 7 years
thanks for the info fella
would not of even attempted it without this thread
__________________
T4 odds n sodds 4 sale
https://www.vwt4forum.co.uk/showthrea...#post972004:db
burrellefx's Avatar
25-04-11, 13:35 #24
N2-UK
Lord of the T4s
I joined the ranks of the happy blankers yesterday.
What better way to spend Easter Sunday morning.
It was very straightforward, thanks to the OP, and the van seems to be running well. Here's to even more improvement once the remaining gunk in in the manifold has dissipated.
22-05-11, 22:23 #25
bugnut
Van Pro
fantastic guide, cheers! mine felt like it was strangled above 2.5k but feels smoother now!
24-06-11, 19:41 #26
compoboy
Lord of the T4s
think ill give this a go tomorrow
compoboy's Avatar
28-06-11, 13:30 #27
jockmcallister
Van Pro
Help For Heroes
All blanked here as of today! No test drived as yet but good to clean it. Struggled to get as clean as the pics here, as i was paraniod about getting the blacked box wet or anything. No MOT issues with it being blanked i take it????
jockmcallister's Avatar
02-07-11, 18:22 #28
compoboy
Lord of the T4s
ill have a go at this in the morning i thnk
compoboy's Avatar
06-08-11, 21:24 #29
livetestleeroy
Van Pro
i thought we were blanking, therefore not alot of point in cleaning? a friend of mine thinks just unbolt it, blank the two ends, totally remove the middle part? is that ok on my 1.9tdi?
livetestleeroy's Avatar
28-11-11, 15:44 #30
pd2h
Van Jedi
My question is the same if you are blanking off do you necessarily have to clean the EGR or is that just overkill??
pd2h's Avatar
Reply
Tags
servicing, tuning
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1.9 PP thread So-Kal Engine & Gearbox 257 10-03-16 08:14
that 'best thread' thread got me thinking... leviticus18_23 General T4 Chat 4 08-12-11 14:48
EGR thread - where's it gone? Gasman Engine & Gearbox 43 10-03-09 17:06
Another how much thread Transpunter General Technical 5 04-02-08 17:20
