Reply
Thread Tools Display Modes
  #11
Old 15-12-14, 14:52
gojira gojira is offline
Van Guru
Default Re: would this work?
Quote:
Originally Posted by Dayvan Cowgirl View Post
Trying to find an affordable solution to sorting out the screw holes in the floor of the rear of my van. Some have gone rusty, some not so bad.
Someone said to weld them but I've been quoted silly money to do it.
Would drilling out the holes and grinding back to bare metal, then treating with a rust converter, then filling holes with j-b cold weld then silkaflexing both sides of holes do the trick?
tbh out of those 2, welding is the cheapest option. clean back rust, blat some weld in, paint it. you could try your local vw club and see if anyone will weld the holes up for beer money?
or you could clean them up and leave them as has been suggested. i have about 10 screw holes in my van floor and i've never seen water come up through them. (i am going to weld them though.)
Sponsored Links
Advertisement
  #12
Old 15-12-14, 15:52
crabs121's Avatar
crabs121 crabs121 is offline
Van Jedi
T4 Post Icon Re: would this work?
How much have you been quoted for welding. Shouldn't cost much. Had some welding on my van think it was about 20
  #13
Old 15-12-14, 19:49
Russ Dylan's Avatar
Russ Dylan Russ Dylan is offline
Lord of the T4s
Geeeeeees you have rust?
SELL IT QUICK!
Sponsored Links
Advertisement
  #14
Old 17-12-14, 15:52
linden linden is offline
Van Master Jedi
Clean then silicon them up, put some heavy grease on the underside. put light oil them from the inside and smear the grease on again from above. If you weld small holes it will cause damage to paint in the surrounding area, you'll end up with having to treat a larger area.
  #15
Old 22-12-14, 15:17
Dayvan Cowgirl Dayvan Cowgirl is offline
Van Expert
Thanks very much for all thge replies guys,
good range of options which have helped me make my mind up. Having now ground the worst of them back to bare metal and drilled out the holes I think i can get away with painting some rust converter in and around the holes then just siliconing them up and undersealing the outside.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
