Reply
Thread Tools Display Modes
  #21
Old 20-04-10, 19:36
dbug's Avatar
dbug dbug is offline
Van Master Jedi
Default Re: T4 Conversion - MK4 Golf 1.9TDI 150BHP ARL Engine
i would think the issues are going to be
gearbox mounting - 1z or ahu straight fit
engine mounting - 1z or ahu redrill and tap
wiring loom - 1z or ahu plugs into the same fuseboard as in donor
all of above will be new ground on here with the mk4 lump. but if your getting it for peanuts then you could be the first. . . . . .
Sponsored Links
Advertisement
  #22
Old 20-04-10, 20:21
Jabe Jabe is offline
Van Man
The scrap yard wanted 800 for the MK4, I would think that is well worth it. We managed to get it started and it seems to run fine. I'll have to look into it. (He wants 800 for the whole car... Well, what evers left of it anyways )
  #23
Old 20-04-10, 21:43
aggie aggie is offline
Meithered to death
Regional CoordinatorOfficial MemberVW Transporter
PD engine sits upright in the golf4 and the T4 motor leans forward alot and the engine bay is not half as long.Oil fitler housing will foul the radiator and coolong fans,alloy sump and oil pickup pipe will need reworking,VNT turbo will be tight up against the firewall,thats if you do overcome the problems i already mentioned.ECU and instruments are all part of the immobiliser system and canbus' if all thats not enough to put you of then crack on and best of luck.
I spent a lot of time thinking about this conversion many years ago and decided that the golf3 TDI 1Z/AHU motor is a much easier conversion and is just as capable powerwise as the PD engine with the correct modifications and mapping.
VWConnections
Sponsored Links
Advertisement
  #24
Old 21-04-10, 01:22
Van Man
Hi, thanks for the informative reply. I take it its going to be hard as the conversion itself will be costly.
Question: When you said the "PD engine sits upright" does that mean the Non-PD engines for the MK4 are more suitable? As I mentioned erlier, I own the 110BHP Non-PD engine, which I remapped from the stock 110BHP & 235nm of Torque to 145BHP & 300nm of Torque.
Would this engine be a good candidate?
  #25
Old 21-04-16, 16:44
stuwoody stuwoody is offline
Van Rookie
Did you ever do the conversion to pd?
  #26
Old 21-04-16, 16:55
d-9's Avatar
d-9 d-9 is offline
Serial Poster
There are a few of these around, its an involved conversion whichever way you do it, with custom engine mount, sump, pickup if you use the t4 gearbox, or custom gearbox mount, engine mounts, driveshafts if you use the golf gearbox, plus obviously wiring.
No nicely documented conversions using the T4 box, but there is one using the golf box.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
TDi Conversion - a quick guide penbryn Engine & Gearbox 56 19-08-19 11:12
2.0 16v mk3 golf engine (abf) into 1.9td?? GAVIN C Engine & Gearbox 48 22-04-12 18:46
1.9d T4, is it the same engine as in a golf? Lovejoy Engine & Gearbox 11 07-12-07 22:47
