Reply
Thread Tools Display Modes
  #641
Old 29-06-18, 14:02
jasshrie's Avatar
jasshrie jasshrie is offline
Van Man
T4 Post Icon Re: Only Audi rims in here :)
Quote:
Originally Posted by U.S.A.-LWB-GL View Post
Tires from 225-50-17 to 255-35-17 can be made to work.
I personally run 235-45-17's on my winter A8 wheels and 235-45-18 on my summer A8 wheels.
A good tire shop should be able to sort you out.
Good luck.
Post up some pics when you get them on!
Just wondering what specific tyres people have enjoyed on the 17inch 7.5 inch wide wheels?
From a size standpont, looks like a 225/55 would be the best match for rolling circumference. Any comments?
Thanks-
Sponsored Links
Advertisement
  #642
Old 29-06-18, 14:57
scruffytoo's Avatar
scruffytoo scruffytoo is offline
More than a little van obsessed
Thanks-
Have run those without ANY issues, mine is standard factory lowered; and was not built for 16"+ wheels
  #643
Old 13-07-18, 08:31
jasshrie's Avatar
Van Man
Default Re: Only Audi rims in here :)
Thanks scruffytoo -
It looks like I can find the 215/60/17 with a 100 Load rating locally (Toyos).
Is the 100T enough?
Thanks again
Sponsored Links
Advertisement
  #644
Old 13-07-18, 10:13
scruffytoo's Avatar
Thanks scruffytoo -
Is the 100T enough?
Thanks again
225 55 17 ................ online sellers like https://www.mytyres.co.uk/cgi-bin/rs...&homologation= have lots of choices
But remember will give a speedo error, depending on what your vehicle was built with. Mine was reading about 4.7% under with 17's
  #645
Old 13-07-18, 13:04
Or_GazM Or_GazM is offline
Full of Cr*p....
Official MemberVW Transporter
I run 245/45 - 17 99LI on my Autec Ethos 17 x 7.5 rims.
Speedo is out by 4km/hr at 100kph....so reads about 4% low (According to GPS)
They are also "legal" in Norway (Load rating IS checked on the EU Kontrol/MOT)
2000 2.5TDi Window van, 7 seater.
Required load rating should be on your door frame panel.
I think 215s will look a little "skinny" on the wheels.
Norwegian roads are opposite to UK roads.....we don't have pot holes, we have ridges that rise up (up to 10cm high) in a sharp peak.
Never had a problem with the wheel/tyre combination, just a load "thump" and all 4 wheels leave the ground!
  #646
Old 17-07-18, 14:05
jasshrie's Avatar
Van Man
Thanks scruff and Orgaz-
Here in Oz the roads vary from perfect to pot-holed with lots of ridges in construction zones, so looking for that thicker sidewall without the thick footprint that tracks.
Scruff, I like your recomendation and have found some Contis 225/55/17 with commercial load rating for ~$250AUD each. I think that's probably the way to go. There were some Yokos with a 101W rating for $179, but in the passenger vehicle range.
Does the T4 Caravelle need to have a commercially rated tyre? I don't recall that being an issue on the 2 previous Caravelle's I've had, although they were earlier mid-90s models.
Cheers and thanks again-
  #647
Old 17-07-18, 15:49
Full of Cr*p....
The Caravelle is a "passenger vehicle".
Load rating for the tyres is actually lower than for a 2 seater T4 van.
Here in Norway, it's classed as a "Bil" (car).
So is a van with "official" rear seats fitted.
  #648
Old 22-02-19, 03:00
U.S.A.-LWB-GL U.S.A.-LWB-GL is offline
Van Expert
Quote:
Originally Posted by scruffytoo View Post
I'm not implying you are a jerk, I don't know who you are or what you do, no more than you know that about me.
I think playing 'fast and loose' for the sake of vanity, as so many would like to do, often needs to be questioned. I think you have in the past posted images of your T4 with both sets of wheels, the flat fives as you call them are not to be questioned.
The big problem comes when people think any old Audi wheel will do; or worse still, they unknowingly purchase 'lookie likies' and then they do collapse. I am sure there are more than dozens running the same or alternative Audi wheels, but load rating recommendations are there for a reason; whatever people may think.
The front end of heavier T4's carries a lot of weight, you then add to the driver, one or even two passengers, and maybe an additional battery under the bonnet; the forces on those wheels can be huge. I realise a lot of assumptions may be worst case scenario, but who wants to be involved in one of those. We also have roundabouts here, again the wheels are put under additional stress. You could go through life trouble free, then again you may not.
Look at all the T4's for sale in Germany for example, very very few of them are full of DIY camper, and a similarly small amount with wheels other than factory. I don't think it is because Germans are boring, but more that legislation almost outlaws such risk (compromise if you like) taking.
I hang out in the whole forum, in the hope my extensive knowledge within the motor industry, and over 26 years experience of owning and running T4's (not to mention a huge library of related information) may be of help to others. I also enjoying seeing what others are doing, I don't have all the answers, but am lucky I can get the correct ones .................. why do you hang out here???
As I always say, if the knowledge helps then great, if people chose to ignore it; it's not a problem for me either.
Finally in relation to the wheel bolts, it is true there are a couple of variations, mainly for wheels we do not see here. I have never tried fitting Audi wheels (that may come as no surprise to you), but I imagine mostly being 'car based' it is probable that bolts with a smaller 17mm head may be required; to give clearance, especially for an alloy wheel impact socket (even a thin wall one). A quality bolt with the correct radius seat, and thread length of course, should not compromise the wheel security.
Because it used to be fun to pop by every few months and see what nice Audi wheels people were running on their vans.
With no one ever coming back and saying that ______ Audi wheel they had run failed.
Now it's just a near pictureless tech thread...
  #649
Old 22-02-19, 03:36
Van Expert
Sorry!
Flippant response after a hard couple days...
Yes, I stand by what I said that it was fun to see what Audi wheels people were putting on their vans.
But no, people should not be running wheels that aren't appropriate.
carry on.
  #650
Old 03-04-19, 15:07
Vctr's Avatar
Vctr Vctr is offline
Van Pro
Some Audi rims on my van. Looks like it from Audi 5000 1983 (code 437601025D). Don't know why the previous owner put it there (wrong load index and everything else), but probably this topic explains why.
Reply
Tags
15", alloy, alloy wheels, audi
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
