Reply
Thread Tools Display Modes
  #11
Old 29-10-16, 14:22
pedalman pedalman is offline
Van Jedi
Default Re: Rear callipers uneven handbrake.
Quote:
Originally Posted by zubzub View Post
The e brake cN be adjusted at each rear caliper. It is in the manual...I have never xone it, but it is not complicated.
Thanks for your reply, Ive just bought the Haines T4 manual so I will give it a go.
Sponsored Links
Advertisement
  #12
Old 29-10-16, 14:58
JonCa JonCa is offline
Serial Poster
Official MemberVW Transporter
Its not clear if the MoT comment was against the handbrake only or rear brakes in general.
If its the brakes in general then the following may apply
If you have surface corrosion on the disc that can make one side less effective than the other. This is because any bumpy rust just wears the pads away and does not help with braking, this rust build-up is why you often find the edge of the pads typically nearest to the centre of the hub are worn unevenly. You can try removing the corrosion build-up with a wire brush on an angle grinder or similar physical method; but as often as not its easier to replace discs and pads on the whole axle.
  #13
Old 29-10-16, 15:19
Van Jedi
The discs aren't too bad, there is a little bit of pitting on one side but its very slight and there is no excessive rust.
I see what you mean about brakes in general or just the handbrake but I cant remember exactly what the mot said. I thought it was just the handbrake because the tester snapped the cable trying to pull it on harder !
Ill try a light disc scrubbing with a wire brush on an electric drill first and do the process of elimination.
Thanks.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
