Reply
Thread Tools Display Modes
  #21
Old 21-09-14, 19:07
chrisradioman chrisradioman is offline
Van Pro
T4 Post Icon Re: How to fit Modern VW steering wheel to 99 T4 with spline adapter
Excellent thread, I've got a 2000 2.5 TDI Caravelle I took the steering wheel off today and tried to fit a MK 4 Golf multifunction but the hole was way to big, I am happy to hear about the adapter so I will order one, I'm going to try and wire the controls to the radio too.
Sponsored Links
Advertisement
  #22
Old 30-09-14, 13:15
purple8's Avatar
purple8 purple8 is offline
Van Jedi
Default Re: How to fit Modern VW steering wheel to 99 T4 with spline adapter
Quote:
OO post back how you get on wiring the controls, do you have a vw stereo and can, or are you trying to use the wheel with an analogue stereo controls.
  #23
Old 30-09-14, 15:59
geeo geeo is offline
Van Master Jedi
http://hackaday.com/2014/09/28/ardui...ket-head-unit/
deffo possibilities here need to get the tools out
Sponsored Links
Advertisement
  #24
Old 04-05-15, 08:23
Last Triumph's Avatar
Last Triumph Last Triumph is offline
Lord of the T4s
I'm about to fit the same steering wheel to my van - regarding the Passat ring - is this a Passat specific part or will other vag rings work?
I just want to make sure I'm shopping on eBay for the correct part.
Are there any specific years or models I need to be looking for?
Thanks in advance.
  #25
Old 06-05-15, 10:03
Lord of the T4s
Thanks in advance.
Anyone know the answer?
  #26
Old 22-07-15, 12:06
revomaster's Avatar
revomaster revomaster is offline
Van Man
Good Morning
I also would like to install my multi-function Steering Wheel coming from my 2003 TDI Jetta.
I have the spline that adjust the shaft from 17 to 27mm, I would like to know if this is a Direct fit
I read from some other forum that we need to cut that spline adapter, as it is a little too long for VW T4 (Eurovan)
I also would like to have the multi-function working on the cruise control, radio control if possible and as well
keeping my horn.
If someone can help with text procedure or picture procedure if any exist, that will be really appreciate.
I have the 4 spoke multi-control that come from a Jetta 2003 TDI and the adapter spline.
Thank you and forward to hear regarding that project.
Have a Great Day
Revo
  #27
Old 22-07-15, 12:07
revomaster's Avatar
Van Man
Good Morning
I also would like to install my multi-function Steering Wheel coming from my 2003 TDI Jetta to my VW T4 2001 2.5 TDI
keeping my horn.
Have a Great Day
Revo
  #28
Old 24-07-15, 20:49
Tubby-1's Avatar
Tubby-1 Tubby-1 is offline
Van Expert
take a look at this thread it helped me
https://www.vwt4forum.co.uk/showthread.php?t=411594
  #29
Old 24-08-15, 20:33
unleash's Avatar
unleash unleash is offline
Van Guru
my question is on the newer vw steering wheels they only have one horn wire instead of two like older wheels ,for some reason my horn wont work not sure why ,new wheel wire assembly doesn't make sense any info would be good
  #30
Old 12-04-17, 11:11
StealthSV's Avatar
StealthSV StealthSV is offline
Van Jedi
Quote:
The second wire just earthed the horn thru the steering column.... It should work when the wheel is fitted...
Reply
Tags
spline adaptor, steering wheel
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
