Reply
Thread Tools Display Modes
  #11
Old 09-11-17, 18:11
fredster fredster is offline
Van Master Jedi
Default Re: Idiots guide to Vag Commander?
Quote:
Originally Posted by regcheeseman View Post
I put all the versions of vag commander into my XP laptop but only ver 3.6 (or 3.4) would give me the option to select k-line as a connection option.
I don't recall any problems with getting the drivers to work - just installed the zip files that I sent you, pretty sure there was a readme type file included.
With the program opened, go down to lower right of screen and drop down the connection options and select k-line (below can bus options)
I read the eeprom, hit the immo off button and then wrote it back.
After switching to K-line, I click the "read eeprom" button, and then nothing happens. The dialog box reads "connecting to device" and then after approx 1 minute it reads "Cannot connect to device. Switch on and off the ignition and try again". I do this, and same thing happens.
I wonder if you could look at your files Reg and tell me which file(s) I click on to install drivers - this is where I think I'm messing up.
I have 10 files in folder Vag_K+CAN_Commander_v3.6.
CDM_setup
FixDiag
FTChipID.dll
FTD2XX.dll
MWB (text file)
MWB_de (text file)
RCMicroDogSetup.dll
Tester
Vag (text file)
VAG VW Tester
Which one of these to I click on to install drivers. And do I install drivers with VAG Commander lead plugged in?
If you could guide me through install drivers process I'd really appreciate it.
Sponsored Links
Advertisement
  #12
Old 09-11-17, 18:35
Van Master Jedi
I'm pretty sure I've installed drivers now anyway. From above files I clicked on "CDM_setup", then from next batch of files I clicked on "DPInst Driver package installer" - this with lead plugged into USB port only (not van) - and got a dialog message at bottom right of screen saying something along the lines of "your device is now ready to use".
So, out to van - plug in, switch ignition on and fire up vag commander. Box pops up saying "open port failed". I ok this. Next box reads "cannot find device".
Tried again, this time with Gaz'z Vag Commander v2.5. This time I don't get those messages. Select K-line, then ECU, then read eeprom. When I do this there is a click from under dash, but then back to the "cannot connect to device" message after trying for a minute or so.
Any ideas?
  #13
Old 09-11-17, 18:40
Van Master Jedi
...forgot to mention USB serial port is set to COM3. In "Tester" file: Can Port=3, KWP Port=3, so I think I'm right to have serial port set to 3
Sponsored Links
Advertisement
  #14
Old 10-11-17, 09:29
regcheeseman regcheeseman is offline
Van Jedi
Any ideas?
I'll check my USB setup, I did have to do a lot of messing about, swapping the plug to different USBs and probably did a re-install of the software at least once.
Getting a click does seem promising
You have the ignition on don't you?
  #15
Old 10-11-17, 09:33
Or_GazM Or_GazM is offline
Full of Cr*p....
Official MemberVW Transporter
Have you tried with your VCDS lead?
I use the same one for both programs.
  #16
Old 10-11-17, 11:56
spotsurf29's Avatar
spotsurf29 spotsurf29 is offline
Van Guru
select Kline and the right com port,
don't switch off immo, find the pin code and adapt ecu/cluster/key....
  #17
Old 10-11-17, 11:58
spotsurf29's Avatar
Van Guru
sorry, I didn't read everything....
v2.5 work like a charm with T4, I got some issue with another version
  #18
Old 10-11-17, 12:47
Van Master Jedi
Cheers guys for various suggestions- will give it another session over the weekend. If it’s not done this weekend I’ll send the ecu to ecutesting.com and they can turn immobiliser off permanently at ecu. Not the cheapest option (150) but need this van back on the road.
  #19
Old 10-11-17, 15:14
spotsurf29's Avatar
Van Guru
I can do it for a cheaper price if you are interrested,
but I don't really like the option of disabling immo
  #20
Old 13-11-17, 17:03
Van Master Jedi
Cheers for offer spotsurf29 but ecu has been sent to ECU Testing. Will report back soon.
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
