Reply
Thread Tools Display Modes
Old 16-06-08, 05:45
Replacing Steering Wheel on 1990-96
SteveGL SteveGL is offline 16-06-08, 05:45
Here is a how to guide to fitting a large hole spline vw steering wheel to your 1990-96 T4.
I own a 1992 T4 caravelle GL and this is exactly how I fitted the replacement wheel.
If your steering wheel is like mine and has totally de glued itself from the inner frame around the top or just want to upgrade, read on.
Early mk2 golfs, polos, jettas etc have the same small hole splines as early T4's. I have heard they fit but the horn
and indicator cancelling does not work, an adaptor needs to be made so the horn and indicator cancelling reaches.
Later vw's used a bush which is basically an adaptor that has the small spines internally with large dia splines on the outside.
This means a late mk2 golf gti steering wheel (as I have used here) fits fine and the horn and indicator cancelling still work.
1st thing you need to find is a late mk2 golf or early mk3 golf(Jetta, Corrado etc from the same era 1990's), this should have the required bush that you will need.
I found a 1990 (H reg) mk2 golf gti in my local breakers, and this is how I removed the bush.
Remove the steering wheel, to expose the bush, as shown here.
Next it might be a good idea to remove the stalks to make it easier to get the puller on the bush.
There is not much of a lip to put the puller legs on so a good quality puller is a must.
Some bushes litterally fall off and some are very stubborn, all down to luck, mine was not too hard to remove.
Here is a picture of the removed bush, unfortunately its too long so some will have to be removed from the end.
The shortened bush, I have very carefully hacksawn and filed flat and level the end so the bush is approx 33-34mm
long total length.
Next remove your steering wheel from your T4, and clean off the splines.
Put a small amount of copper slip grease on the splines to aid removal in the future. (You never know!)
Locate the bush on the splines ensuring its the correct way round, and using a couple of washers as packing, fit and do up the
steering wheel centre fixing nut to insert the bush fully onto your column.
This is what it should look like after the bush is fully home.
Thats it, you are ready to install your new steering wheel.
This is the gap I have to the steering colum covers, about 3mm approx, as you can see the horn contact is touching correctly.
I had to put a thick (3mm) washer the same diameter as the steering wheel centre locking nut under the centre fixing nut so the nut is clamping onto the steering wheel correctly.
So in summary, 15 for the bush and a tidy late Golf gti mk2 steering wheel.
15 and a couple of hours one afternoon well spent.
I chose this steering wheel because its chunkier, a bit smaller (360mm dia) and keeps the factory look.
Hope this helps and inspires owners of early T4's to get rid of that old, de-glued or just plain large standard wheel.
Cheers.
Steve.
__________________
When you're right, no one remembers.
When you're wrong, no one forgets...!!!
SteveGL's Avatar
SteveGL
Van Pro
Official MemberVW Transporter
Re: Replacing Steering Wheel on 1990-96
12-04-14, 21:41 #11
joseph1972
Van Pro
Anybody got a pic of the vw part that's mentioned?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steering wheel help needed ... chain-link wheel RichardM2319 Steering & Suspension 10 01-09-11 10:23
Steering wheel Trailjunkies Steering & Suspension 0 07-02-09 10:58
VW T3 /25 crewcab 1990 m666blp General Van Chat 0 06-05-08 06:58
steering wheel for t4 t4olga Steering & Suspension 15 09-02-08 19:55
