Reply
Thread Tools Display Modes
Old 29-03-12, 21:39
Outer CV how to replace
tiggerjpt tiggerjpt is offline 29-03-12, 21:39
Remove hub bolt 23mm I think.
Remove lower ball joint 14 XZN (spline) needed
Pull hub away from shaft
Drive the hub bolt back into the hub
CV will pop of the shaft, cut boot clips
Remove joint and note position of seals and clips and remove boot
Clean the shaft and apply thin layer of new grease to splines
Instal small boot clip and boot slide them up the shaft and fit CV seals and clip and some grease
Pack the grease well into the new CV and work it into the bearings
Press the joint onto the shaft and tap it home
Fit the boot and crimp the boot clips.
Now put it all back together, you may or maynot need to remove the bottom bolt from the shock absorber to aid setting everything back up. Make sure everything is well tight and your sorted.
tiggerjpt's Avatar
tiggerjpt
Van Jedi
Re: Outer CV how to replace
12-04-14, 20:51 #11
jensjakob
Van Jedi
Your lower balljoint boot is split...
But great writeup - just what I needed.
Looks like a 2 hour job - including finding the right tools, cleanup afterwards - and a brewski.
Happy driving
Jens Jakob
Sponsored Links
Advertisement
25-04-14, 00:20 #12
tiggerjpt
Van Jedi
Happy driving
Jens Jakob
Thanks, don't worry she's got nice shiney new ball joints just after that job. Still to do top ball joints
tiggerjpt's Avatar
09-07-14, 20:37 #13
adaptive8
Van Rookie
I might be asking this on the fear that I am a big girls blouse but I've:
1) Removed the wheel and central hub nut.
2) Removed the two lower ball joint nuts.
and now I'm pulling at the hub (still with the disk and calliper attached) hoping it will come off.....but it doesn't. Do I just need to grow a pair or do I need to take something else apart (besides my aunts wardrobe).
G
11-08-14, 20:22 #14
tiggerjpt
Van Jedi
G
Yes you are a blouse
anyway from memory I couldn't do it either so I put a jack under the disk abd jacked it up slowly and it will pull away from shaft.
tiggerjpt's Avatar
26-09-14, 15:23 #15
Kayakmick
Van Man
When you say cv joint pops off Is there something I'm missing if mine will not budge even with a big hammer??
09-01-15, 18:00 #16
tiggerjpt
Van Jedi
Quote:
If the wheel hub is clear of the vc then drive the centre bolt into the joint and it will come of the shaft.
tiggerjpt's Avatar
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
