Reply
Thread Tools Display Modes
  #3651
Old 05-08-19, 06:37
Gsmithy's Avatar
Gsmithy Gsmithy is offline
Van Rookie
Default Re: 2.4D AAB Turbo Project
Thanks Alex300. done this. its so much better now.
also have an intercooler to fit when i can
Sponsored Links
Advertisement
  #3652
Old 20-08-19, 17:12
Uravinalaf Uravinalaf is offline
Van Man
Breathing life back into this thread and hopefully my seemingly gutless abb....
Iím getting all the bits together for this conversion and am pretty much there now but would appreciate any pointers possible for the airbox to turbine induction pipe/fittings and whatís worked for you?
Iíve got the old style cylindrical air filter in the barrel type air box and would like to keep as Ďstockí as standard if possible.
The van came with a piper filter and I was glad to get back to standard and away from the roar of the Ďupgradeí
Am I right in assuming I need to get from 70mm from the airbox to 50mm at the turbo flange through a couple of bends in the process?
I only intend running at 0.6 boost so hoping to avoid an inter cooler if possible.
Any pointers from your induction setup/experience?
  #3653
Old 31-08-19, 00:34
planetc planetc is offline
Van Guru
Default
If you have the original pipework from the donor you should find that you can use a mix of the aab airbox and a combination of the pipework from both. That's how mine works anyway.
Sponsored Links
Advertisement
  #3654
Old 11-10-19, 12:20
Brookster's Avatar
Brookster Brookster is offline
Serial Poster
Official MemberVW Transporter
Good afternoon everyone
sorry i havn't been on here for a while i've been busy this year with the Business & Dragons Den - https://youtu.be/8PxE0bQX_ww
You shold be able to run 1bar boost with no intercooler and no major issues , if your getting loads of smoke at 0.6bar you need to turn the fueling down or increase the boost to burn the excess fuel .
Fuel feeds boost but if your on STANDARD wastegate pressure you will only get 0.6bar max no matter how much you increase the fuel and the EGT's will increase due to the excess fuel.
Fit a manual boost controller for £10 to increase the boost
T4 SWB 2.4D Turbo
  #3655
Old 11-10-19, 14:27
splitbusvanatic splitbusvanatic is offline
Van Man
Bloody hell Mate. Well done. Delighted for ya. Great news you got the dragons on board.
Youíre a mighty bit of stuff. Good luck with the partnership. Dan.
  #3656
Old 11-10-19, 15:54
alex300's Avatar
alex300 alex300 is online now
Van Master Jedi
Well done Brookster, I bet that was bloody nerve racking, as they started to pull out I thought he's lost it here but you got there in the end, good luck with the new venture mate
  #3657
Old 12-10-19, 14:58
Brookster's Avatar
Serial Poster
Quote:
Thank you
T4 SWB 2.4D Turbo
  #3658
Old 12-10-19, 14:59
Brookster's Avatar
Serial Poster
Thank you been very busy since the show
T4 SWB 2.4D Turbo
  #3659
Old 12-10-19, 15:54
Fraseb01's Avatar
Fraseb01 Fraseb01 is offline
Van Jedi
Great product mate , love it
  #3660
Old Today, 18:29
Van Man
Fit a manual boost controller for £10 to increase the boost [/QUOTE
Thatís helpful, Iíd wound the wastegate rod pretty much to the end of the thread without any obvious variance.
One other noticeable issue is juddering at low revs, Iím enjoying the improved Ďpullí but find the van needs far more work through the lower gears when driving round town.
Any link to the above/fuelling?
Reply
Tags
2.4d na, 2.4d turbo conversion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anyone with a 2.4d turbo conversion? TootallPaul General T4 Chat 7 09-05-14 18:19
2.4d AAB - head off - Tips and tricks ? project 2006 Engine & Gearbox 3 03-12-10 20:49
2.4d AAb Cambelt cover sid023 Wanted 0 13-05-09 21:48
2.4d aab engine T4 NATH Wanted 3 04-08-08 17:12
New Member with questions >> 1995 AAB T4 5cyl 2.4D Multivan in SW France jasonic New T4 Members Forum 6 01-06-08 16:25
