Reply
Thread Tools Display Modes
  #31
Old 12-04-17, 12:15
StealthSV's Avatar
StealthSV StealthSV is offline
Van Jedi
Default Re: How to fit Modern VW steering wheel to 99 T4 with spline adapter
Quote:
Originally Posted by N13L VV View Post
ok guys ive wanted a nice steering wheel for ages now so have read up all the threads i could find about what fits etc. Anyhow i firstly bought one of the nicer T4 steering wheels with the chrome badge that was a straight fit but i still wanted something different . I then bought a nice MOMO wheel and boss that had been fitted to a golf . But that didnt fit so after a bit of investigation i sussed out i needed the spline adapter from VW part No. 191 419 514. i then came across a lovely 3 spoke leather vw wheel from a passat in a breakers yard and really fancied it .
Here it is fitted , It is a lovely chunky wheel to hold and the leather feels nice . also it cancels the indicators with the little ring i got with it from the passat.
Now for the progress pics
First take off the steering wheel centre / hornpush to get at the big nut that hold the wheel on . now take off the nut and slide the wheel off
Next get the Spline adapter VW part no 191 419 514. to bring splines up from 17mm to 27mm
At first i thought the adapter didnt fit but i was just an extremely tight fit . I just greased up the inside then placed it on and screwed down the big nut to slide it on.
next take the plastic ring from the passat and trim of a few bits that are not needed but make sure to leave the indicator cancel tab .
The plastic ring has a couple of pins that locate it on the back of the wheel , so pop it in place and your ready to fit the wheel. Now you are left with a bit of a gap so i just used a rubber sleeve from an old boss to cover the gap .
you will also need a big washer as the nut is almost same size as the large splin hole and you dont want the wheel coming off in your hands . Tighten it all up , pop in the centre and job done .
Looks nice through the window i think , nice and modern but still with a factory look .
im now left with 3 spare wheels ill be selling soon lol
Hi. I went from the standard wheel on my '96 T4 to the one top right in your last picture. Problem is it's slightly loose on the splines. It deffo doesn't need to go from 17mm to 27mm, seems more like it could do with 19mm....
Has anyone got any ideas on this? Cheers..
Sponsored Links
Advertisement
  #32
Old 18-02-18, 12:42
curtvw curtvw is offline
Van Rookie
Hi guys , want to fit mk4 golf wheel to my t4 but struggling to wire horn & how in god name do I fit the indicators cancel tab .ive got the ring from golf but in stuck from there....
  #33
Old 21-04-18, 22:04
Mocco7 Mocco7 is offline
Van Man
Was thinking of changing the wheel on mine. This adaptor does it work in the same way it does on late 80's VWS when they started putting on an adaptor as the steering wheels had bigger hole The earlier VW used the same size splined as a Porsche, If its the case my 99 T4 as the same smaller splined fitting I could replace my wheel with a nice 928 steering wheel
Sponsored Links
Advertisement
  #34
Old 21-04-18, 22:13
Or_GazM Or_GazM is offline
Full of Cr*p....
Official MemberVW Transporter
Spline adaptors work, but you have to mess around with the horn contacts and self cancelling for the indicators.
Also, need a "packing" piece to fill the gap between wheel and cowling.
There are a few threads about it on here.
Reply
Tags
spline adaptor, steering wheel
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
