Reply
Thread Tools Display Modes
  #21
Old 13-09-13, 14:20
Bluebird Customs's Avatar
Bluebird Customs Bluebird Customs is offline
Lord of the T4s
Default Re: shock horror!
Quote:
Originally Posted by rhysvw View Post
That one is only a 5mm seal which is alot smaller than oem I do them with the correct size seal have a look at the website
http://www.bluebird-type2.co.uk/t4%2...or%20parts.htm
Sponsored Links
Advertisement
  #22
Old 13-09-13, 14:55
Jim Doodle's Avatar
Jim Doodle Jim Doodle is offline
VWT4 Forum Administrator
I Support MacmillanI Support CLIC SargentI Support Cancer Research UKI Support Children In NeedOfficial MemberVW Transporter
Quote:
Originally Posted by Tomsy07 View Post
I recently purchased the tidy one 2 inches short, but it does the job.
You installed it wrong, they need pulling tight as you install them. I have the Tidy T one and indeed my first fit left a 2 inch gap, so i took it off and pulled it tight on my way round fits perfectly
  #23
Old 13-09-13, 15:52
Mat_rasky's Avatar
Mat_rasky Mat_rasky is offline
Lord of the T4s
Quote:
I think we have a winner with the tidy ts then! Thanks for the input
Sponsored Links
Advertisement
  #24
Old 13-09-13, 21:59
rhysvw rhysvw is offline
Van Jedi
They do a 6mm as well, whats the OEM ?
Is the tailgate seal a different size to the doors ?
  #25
Old 14-09-13, 08:13
linden linden is offline
Van Master Jedi
I came across this on VGC,
http://www.thevehicleglasscompany.co...uct--1505.html
any good?
  #26
Old 14-09-13, 10:29
jgoo's Avatar
jgoo jgoo is offline
Van Jedi
I Support CLIC SargentOfficial MemberVW Transporter
any good?
Above looks like a spot on match, or very close.
Took pic of my seal for comparison.
  #27
Old 24-09-13, 17:57
Mat_rasky's Avatar
Lord of the T4s
T4 Post Icon Re: shock horror!
Ok so heres what was happening..
lots of water getting in
I took the seal off entirely and refitted leaving the gap elsewhere but as you can see pretty rough looking..
poured water from outside around the area where the ends meet. And in in flowed.. it comes in and down the middle of the seal. very wet everywhere.. explains why the water wasnt just in one place. And when it comes in its not just a bit.. its a lot
I have ordered the tidy ts one today. As much as id like to get the oem part I cant stretch to that.. considering I didnt plan on having to do the job at this stage..
I will take heed all the advice when fitting and let you know how it works out..
hopefully it solves the leak!
  #28
Old 24-09-13, 18:09
Van Master Jedi
On the 3 t4's I've had all of them have the join at the bottom to the left of the tail gate catch
  #29
Old 24-09-13, 18:50
Mat_rasky's Avatar
Lord of the T4s
Mine was bang under the catch.. but I took it off and refit to see if it was causing the leak
  #30
Old 26-09-13, 12:57
Mat_rasky's Avatar
Lord of the T4s
The seal arrived today and has been fitted. Impressed with the service from tidy transporters. Top notch
it is indeed a bang on match came to 47 sterling.
And it was even the correct length too! Touch!
Thanks to all that chimed in.
if you need any seals save your self 50 quid and head to tidy t's!
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
