So long as you can see down the side of the towed Caravan / Trailer / Horse box then you are fine. Almost all Caravans will need an extension for both sides, but as you found Horse box trailers are not always that wide.
T: If ever you do need them I used the ones with rubber straps over the back of the Mirrors. I used to use more expensive ones that screwes down to clamp onto the top edge. But found they vibrated too much. The cheaper ones still move, but you can at least see.
sometimes its not whats legal or not legal ,its what you are comfortable with
i bought some cheap mirrors and adapted them using a hot air gun to get the best fit on the t4 mirrors
i nearly bought a lhd pair to see what was better but when your towing a 7 foot 6 wide caravan you dam sure need them
Related Threads
VW T4 Forum - VW T5 Forum
3.5M posts
221.6K members
Since 2007
