Closed Thread
Thread Tools Display Modes
  #21
Old 17-08-11, 11:26
daveyjay daveyjay is offline
Van Rookie
Unhappy Re: Please post your engine Type in querries
Quote:
Originally Posted by aggie View Post
This is just a suggestion to members of the forum who thread and post in the engine section.
Can we all please when asking for advice about thier engine or related problems state what engine they have as far too many times i will read a thread and not have a clue what engine they have and find it difficult to advise because the advise is different for all the different engines found in the T4!
Can we have a sticky on this thread please jimbo?
i just fitted 1.9 tdi alh engine new turbo recon cly/head everting was fine started her up run on tickover till warm then reved it up an it went crazy full revs red line switched it off didnt had to cut battery terminal still ran at full revs for a minute neva came across this problem before need help any ideas what caused this doin my brain in daveyjay all help will be appreciated
Quick reply to this message
Sponsored Links
Advertisement
  #22
Old 01-10-11, 22:55
MR OX's Avatar
MR OX MR OX is offline
Van Master Jedi
Default Re: Please post your engine Type in querries
Check your oil, sometimes a turbo seal can fail & the engine will redline out on it's oil & fuel until it explodes.
  #23
Old 25-10-11, 21:13
milly600 milly600 is offline
Van Expert
T4 Post Icon Re: Please post your engine Type in querries
hi guys ive got a mk3 golf tdi 1z engine that im going to use in my t4 but before i remove it i want to sort the running problem out, right on idle its up and down and at 70mph/80mph it has a slight judder(no smoke) like its running out of juice ive pluged it on my scanner but no codes found any ideas? could this be the start of fuel pump failure? if i cant sort it its going to the scrappy
Sponsored Links
Advertisement
  #24
Old 30-10-11, 19:24
Rich G Rich G is offline
Van Guru
Sound's like a needle lift senor, I had the same problem 300 new or scrap heap challenge
Rich
  #25
Old 31-10-11, 15:14
craney's Avatar
craney craney is offline
Van Jedi
afternoon all new to the forum just bought a 98 long nose velle i have owned it about 10 weeks now done a few bits lowered it 85mm bonnet bra 18s fatboy black bars curtains on way from germany and its in the paint shop as we speak but it only has the 2.4 d engine can anyone tell me where to get the 102tdi engine fitted even better supplied and fitted or should i go for the tdi conversion for mine not sure and could do with some advice struggling to upload pics will try again later thanks cranny
  #26
Old 31-10-11, 20:57
Van Expert
Is that something I can remove from the pump with out removing the fuel pump complete ???
  #27
Old 31-10-11, 23:41
Van Guru
Its on injector no3 the one wire coming out of it, i got a second hand one from a scrappy sadly I had to buy a complete engine !! but it was cheaper than a new one !!!!
  #28
Old 01-11-11, 22:07
Van Expert
Cool il get down the scrappy the weekend il keep ya posted thanks again.
Closed Thread
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Location
Where you live
First Name
Surname
Postcode
Postbit Orientation
Insurance
Body & Engine Type
Tell us about your van.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hi Moderators!!! Dermot General T4 Chat 14 09-01-09 16:58
ATTN MODERATORS!!! Help Rhosneigr Gaz General T4 Chat 3 15-02-08 19:59
Moderators - FYI!!!!!!!!!!!!!!!!!XXXXXXXX! hendrix General T4 Chat 9 09-01-08 19:21
