1 - 9 of 9 Posts
Hi All,
I have an oil leak from my 1.9 td (ABL) its from above the oil filter, something that looks like a dizzy without the cap or leads :*
can anyone let me know what it is I:
cheers all
Hi I have the same problem with my 2.5tdi caravelle. Is there a seal that can be replaced or does it need a new vacuum pump unit?
I have also just been told my vacuum pump is leaking...didnt say anything about changing o rings / seals just suggested fitting new pump....he's a good Mechanic so trust his word but Is It worth changing seals first ...is there a particular area this can leak from which would instantly suggest the pump needed replacing ?
Thank you
Thank you
I would say the pump itself never leaks so deffo go with the seals first
1 - 9 of 9 Posts
