hi guys got a timing issue. timed the ahu up using pump lock cam lock and flywheel mark.starts fine sounds ok . plugged in vag com and getting code '00550 start of injection regulation'.on the tdi timing graph it says 'too advanced to plot' .i have moved the pump through the adjustment and the best i can get is 215 .is it common to move the pump a tooth or two to set up on the graph ???
or could be an electrical problem with the loom ???
