Ok, got hold of a vw caddy with ahu engine, swapped engines over to my 1x powered t4, did the wiring as per the wiring help list on the tdi help pages, immobiliser (8 pin and 3 pin plugs) is swapped over as is the transponder from the key. Went to start her up after connecting all wiring and have the following happen
Starter motor works and cranks the engine
No lights at all on dash :-S
Can't connect to ecu with vagcom or immo
Any suggestions as I am stumped, its wet, im tired and feeling now very fed up!!
Thanks in advance!!!
