I need to remove my tandum pump on my t5 1.9 tdi 2008, how do i remove the brake servo pipe on the pump, is there a clip, once removed how do i remove the tandum pump please
haynes mentions the brake servo pipes some have clips others may not, didnt wan to force it and break it
i can seen three bolts haynes says 4 will have a look again tomorrow, the palstic water pipe just under the tandem pump, does this stay where it is when pump is removed or does it need to be removed first
