I'm trying to source a crank damper/harmonic damper for my 1.9d
GSF and Euro only have the ones for flat belts and VW don't recognise the part number
I need the damper itself and the power steering pulley which press fits into it. Obviously the rubber must be in good condition!
Can anyone help please. Maybe someone who has done the 1.9 tdi conversion???
hi there! i just brought one from gsf and they had the right one... even for grooved belts... got it all fitted along with cambelt, new auxiaalry belt, new power steering belt, water pump... the lot basically, and now the van has been written off :( im allowed to take bit off to an extent as long as i replace with another... e.g. i have a split charging alternator, but no ordinary alternator to replace it with :( so at the moment its being scrapped with a split charging alternator :( and a brand new crank pulley :( i still have my old one which did have a bit of wobble in it... but i really cba to swap the pulleys sorry... but i will fine out if its going to a breakers yard and if so when it goes in... if this helps??
