Hi peeps
does fitting the PP injectors make it use more fuel,,
plus anyone explain how fitting new/different injectors makes such a big power difference or is it just on 2.5TDI"s
Wanting to fit em to our 1.9TD ABL
Range Rover Sport Ally IC On Its Way :cool: "Fingers Crossed"
Meithered to death
Your 1.9 is indirect injection and the injectors are completely different compared to them from a 2.5TDI,there are other options for your engine and tuning it.Keep searching on this and moreso specialist diesel tuning forums.
There are guys in norway extracting 200+BHP from the ABL and similar enginesA:
,,,cheers buddy will doT:
'Uprated' injectors for the 1.9 are a recon job, with the break pressures upped - although last quote I got was £40 a pop and that only supposedly helped when using the (thicker) veggie oil, with perhaps a 5% power increase.........
I guess the incresed flow rate for the thicker fuel would also indicate a reduction in MPG, but that would be a guess........... :)
