I have just found out that my 1.9td abl engine has a cracked piston and head.
I therefore need a new engine asap what other engines will fit with minimal fuss?
What about a passat td engine? What is involved in the swap if it is easy i can just swap over a few bits like sump etc then it will make it easier for me to source a new lump if it involves a lot of work i would just look for a transporter 1.9 td engine!
Any help on this subject or a push in the direction of someone who knows would be hugely appreciated thanks jim
Bump as I would like to know if anyone runs a AAZ T4 on here?
Cheers T:
Yes it has been done by myself and other a few times. you need to swap the sump, dipstick to the front of engine, exhaust manifold and turbo, water hose flanges, vac pump, rocker cover, ps pulley and a few things iv no doubt forgot. it is almost the same block and head as the ABL engine
