just changed camshaft on my t5, when resetting the timing belt the timing illustration on auto data program are different to whats on my engine. its a 07 2007 model, the auto data shows the bottom crank pully with a line marked on the crank above the bolt hole, but mine has a arrow inbetween holes. the cam shafts marks are also different? has anyone had this problem before??
The camshaft sprocket will only fit one way and has a groove cut into the back piece so a locking pin passes through it into the cylinder head. With regard to the crank, put the lore cover on and the loosely put the crank pulley on and see if the cut out on the pulley lines up with the notch on the cover
looking on the auto data program the set up i got on mine is the same as a passat engine?? the program only goes upto 2007 so do they change in later 2007 or?
