Hi all, I'm just in the process of fitting some new seats to the van, drivers side is power only adjustment. I've worked out what powers what, just a positive and negative, I was going to run positive from the fuse box but I took one look at the jumble of wires in there and bottled it. So anyway for simplicity, I'm now thinking of running my positive straight from the battery using a ring terminal, then a in line waterproof fuse 20amp near the battery, then connecting to the seat positive with a 30amp block connector, negative will be on the seat basebase, the wire I have got is the same stuff as is on the seat, which is 2mm 25 amp. Is this a safe setup or should I just bite the bullet and get an auto spark to do it ?
Many thanks
Rich
