You don't say what dash cam you have but ive a Garmin 45 and they do a cable for 20 quid that you wire in to the loom,which gives the cam a pernement feed for when your parked up so it detects movements at the cam lens or a G sensor which detects bumps and records automatically.
It has a low voltage sensor also so it will not drain your battery if its parked up for extended periods.Dare say other dash cam manufacturers will do the same or a sparky could throw something together.
