1 - 11 of 11 Posts
Anyone upgraded their discs, steering seems to wobble when braking now so put it down to warped discs. Wondered if anyone has put on drilled and grooved discs if so what should i expect to pay and where would i get some from.
Super Moderator
demon tweeks does an upgrade for cross drilled discs but there is 3 sizes of discs for the t5. The disc they do is for the middle size disc which i think is for the v6 petrol. brembo don't do a kit i've asked for my sportline.
Super Moderator
hi have you any part nunbers that you can post? was it a complete kit? i've been trying to fit 333mm discs but the calipers need to be changed. larger discs were fitted on 174bhp with 17" wheels. Thanks:D
hi festa unfort no partnumbers available , because the only bit that was vag was discs off of an audi r8 and calipers came off an aston db9 had to make my own caliper mounting brackets bit of a mission but it all works perfectly
Super Moderator
have you got any pic's ? and how did you make the adaptor bracket? was it home brew or a machine shop?
1 - 11 of 11 Posts
