1 - 17 of 17 Posts
Super Moderator
What happens when a gear box fails:* ok I now it doesn't go along or it makes funny noises :) but what happens before:* does it not go into gear, make crunching noises or a droning noise. Mines just making a noises at between 2200 and 2700 rpm in 6th and it sounds like the lay shaft with end float.:eek: now after spending a bit of money on the engine it's really the last thing I want to go but if it needs a new box can the one I have got be updated or is it going to be an exchange. It maybe something to do with the power through the box anyway:D but don't want it to seize up while on the motorway :( merry Christmas everyone*<:)>
Mines the same mate! Doesn't like going in to first and crunches in 3rd and 5th!! I know the release bearings wearing out cos its whining when the clutch pedals down!! You can get them referb but I don't know how much it costs :*
Merry Christmas dude *<:)> :ILU:
the last person i sploke to who was getting a gearbox replaced on a 174 said it didnt make any noise, no rumble no not going in gear, it just went bang, then lots of crunching and no drive in any gears , not even reverse,,,,,
i recomended a place near me called blackdiamond transmitions, here is a link and they are very good...
http://www.motwarrington.co.uk/
Currently, on my 2.5/130 I have no 6th - it just started "easing" itself out of 6th on the motorway, cruising at around 70 - no noises of any sort prior to going. Still drives in 5th, although the lever moves back & forth as you ease the power on & off (does not do it in 1/2 or 3/4th).
It's going in for a recon box in the new year.
I looked at getting my gearbox repaired but did not want the downtime as it's a working van. Recon boxes see to go from about £600 > £2.500 (for a VW/TPS one).
Found one for £1,300, £300 for fitting (at the same place) with 3 months/9,000m warranty.
Just to add, talking to people it seems that the T5/2.5 boxes tend to "just go" with little or no prior warning.
I'll post how I get on.
Next job after that - a stainless steel exhaust, rear springs, Caravelle headlights & a respray. (will leave team silver & join team black or grey).
Super Moderator
I like black but a pain to keep cleanT: don't know about grey:* the gear box seems to have got noisier since the engine got rebuild and like you bc it's a working van. May go the route of getting mine overhauled as I know it's history but don't want to go the same way as the engine. I think it sounds like wear in a bearing as if you keep the power on its not there, it's only when you seem to cruise that the noise is obvious. if it does expire at speed I don't really what it to lock the front wheels or do more damage as its a new dmf and clutch os is it better to get it fixed before it broke or get it fixed when it breaks:)
If it were not for the time issue I would have definatly gone down the route of getting my own box rebuilt. From my very limited knowledge of gearboxes my money would be on bearings &/or worn syncro's. I did have a quote of "around £850" to have my gearbox taken out, repaired & put back in again (place near Dartford) & would take 3/4 days which I though may very well end up 4/5 days - possibly more if any parts required had to come from Germany.
I've had black in the past & know what it's like to keep clean (1976 mkI Escort Mexico), but it does look nice. My wife has a new Golf in metallic black & that does not seen as bad as solid black. Then again, I've had a dark graphite (mkII Astra Van) & that not only looked nice it was not too bad to keep clean.
After some thought I decided to spend some money on what I have now (54 plate 2.5/130, LWB with most of the toys I want). Personally, I don't think the T5.1 "cuts it" - dosent look that much differnt to the T5 & I'm not convinced (yet) about the 4 pots. A lot of cash to lay out, so when I do, maybe to wait for the T6 ?
I expect I will end up spending about what it's worth, but at least I'll know exactly what's been done to it & I'm not one to change my vehicles that often.
I've had a stainless exhaust system fitted, lovely sound from the 5 cylinders!! T:, got the black led drl headlights, sportline suspension and being resprayed in viper green in may next year T: *<:)>
Super Moderator
I have to agreeT: PP decat on mine with 235 odd horses and picks up like a petrol nowT: sportline looke likee (but with more toys) in black magic soon to be under candy:D
That must sound mental!!! :ILU: and quick as f........ T: A: looks awesome too!! T: be nice to see when it's been can-deed T: can't wait for mine to be done!! Gunna look the dogs dangleys T:
Super Moderator
Discussion Starter #11
Also going to do the through hub mod for the front shocks just to drop her a bit more:) but be all a waste of time if it just sits on my drive:( got builder jays old bonnet so that's having the angry lookT:
Nice one T: I would do that with mine but I need it and use it as a work van so wouldn't be very practical :( yours is gunna look the nuts after your finished with her then!! T: be all worth while!! I'm de-badging mine and having the "bad boy bonnet" conversion T:
Super Moderator
Discussion Starter #13
Aj I got a big list to get through at the beginning of the month. Forge calliper conversion with black diamond cross cut and drilled discs front and back, red stuff pads. H and r anti roll bar with bushes front and rear, updated drop links and the sportline rear lamps off the new van
:jd:jd:jd:jd holy !!! Well I think you should share some of those toys this way!! I: lol.
Fair play mate! She's gunna b awesome when you've finished with her!!! T: A:
Festa,would you consider the VW Racing AP 6 pots like i have on my Caddy Sportline?
VWR will be putting the kit into production if we can get enough interest...I was going to buy Forge but had a bad time with fitment of my hoses which only got sorted after about 6months of constant emails
Super Moderator
Discussion Starter #17
Could do all I need is the callipers,carriers and braided hoses as the discs are coming from h and r . Let me know on a rough priceT:
1 - 17 of 17 Posts
