1 - 11 of 11 Posts
hi
has anyone have for sale a 18 inch wheel for a t4 with or with out tyre
going away soon and dont have a spare
If you have a standard wheel as a spare it will be perfectly adequate to use this - as a get you home/place of repair. T:
A large majority of cars on the road have a spare that is a different size to the usual road wheel size, and they are used daily without any issues.
on that way if you will get punkture on front tyre you will need to swap yours tyres with rear ones, otherwise you might kill your gearbox,front wheels must be the same mesure
thanks for the replies , not in so mutch of a panic knowing that you can use the original spare
explain? :confused:
So if one wheel spins on a wet/icy surface (smaller wheel rotating faster than a larger wheel), and the other remains with traction this will damage the gearbox?
Similarily - if you have one tyre with good tread and one with none this will also kill the box?
explain? :confused:
Or if you turn a corner! :eek:
explain? :confused:
I think the guy was looking too much into a differential on doesnt know what one does or how it works mechanicaly ,
but i will say the the planet gears in a diff do not run on bearing they run on bushes so they shouldnt be continuously used
as a temp get you home thou its not going to hurt but it wouldnt be a good idea long term otherwise yes it will damage the diff bushes T:
on bmw i had when i was student i put diferent sizes tyres on rear axle,there became noticeble noise maybe after 500km. gearbox will not fall apart stight away,but it is not recomended to use diferent sizes tyres on driving axle
1 - 11 of 11 Posts
