1 - 9 of 9 Posts
So I've decided to ditch my 17" Devonports (because they are silver) and decided on some nice graphite 18" jobbies, looking at tyre choices until my head is spinning, 255-55-18 seems to be the go to size but looking at 245-45-18 means I can get my favoured Michelin Primacy's.
So will these be ok or are they too small/ narrow I'm quite confused by all these numbers o_O...
You don't mention what tyre size you're running at the minute or what width the new 18s are. Have a look on https://www.willtheyfit.com/ - you can enter the rim size/width (and offset) as well as tyre sizes and it'll show how much bigger/smaller the various tyre options will end up.
255/45-18 is the correct size to be the same rolling radius as std.
It used to be easy to insert a picture!
I'm running uniroyal rainsport 3s at the moment. 255/45/18 don't have any complaints about them so far and they're reasonably priced.
This all sounds a bit strange. Stock sportline 8.0J x 18" wheels are ET53. Deliberately changing the offset by 20mm will have marked effect on the handling. Torque steer and braking wobble will be worse too.
I see there are 2 versions? Only the ET32 is rated to 1660kg per axle (>T32 load). I think 1490kg is too low for any T5?
245/55R18 isn't a readily available size either. 255/45R18 is common and easy to get when you're away from home.
This just isn't something I'd gamble with when a T5 is so a nice vehicle to drive?
18 x8
ET 32 (5x120) 82 Centre Bore Load 830 Kg
18 x8
ET 44 (5x120) 82 Centre Bore Load 745 Kg
1 - 9 of 9 Posts
