1 - 20 of 63 Posts
Originally Posted by matt tdi
come on guys & girls still got lots on offer here
cab doors £30 each
cab door hinges £10
cab door mechs £15
cab door handles&window winders £5 each
n/s barn door £30
barn door hinges £10
barn door internals/plus mech £25
bonnet pull & cable £10
front cab step covers £10
dash £25
rad £30
hubs £20
suspension £30
indicater/wiper stalk £10
switches/hazard £4
barn door stays & lock locaters £10 a side
speaker covers £8
dash clocks/speedo/ temp fuel speedo clock £25
discs front & rear only done just over 3000 £15 for fronts
hand brake cover £12
gear lever gaiter £12
seat belt lap belt £10
ignition cowl £10
fuse box cover £10
vents £5 for the two sides
slidiing door rail end cap £5 & internal handle £10
sliding door witches hats & piller side hat locaters £10
dash blank & engine management cover £5
head light switch & fog & dimmer £10
clutch slave cylinder £15
gear shift and linkage £15
power steering rack £40
& lots lots more prices do not include postage and you are welcome to arrange your own courior
come on guys plenty here at good prices
Matt do you have a grab handle from above the passengers door? Also the panel that sits between the dash and the lower box? Joiner panel?
hi mate,
I am after drivers seat belt, drivers wing mirror unit, sliding door bottom racket (roller thing), horn (speaker unit that sits at bottom of engine bay) and if they are in good cond the rear disk brakes & pads + a price on postage/courier to retford, notts.
mike
Discussion Starter #10
hi mate,
mike
you have pm mike
Discussion Starter #13
cab doors £30 each
cab door hinges £10
cab door mechs £15
n/s barn door £30
dash £25
rad £30
hubs £20
suspension £30
grille £10
switches/hazard/window heater £4 each
speaker covers £8
ignition cowl £10
fuse box cover £10
front pannel £20
some on here must need something :D
Is the grille the badged one? and if so does it have attachment holes at either side as well as the hole in the middle of the badge?
1 - 20 of 63 Posts
